changing oil brands?
Old Nov 26, 2009 | 02:18 PM
seclineman's Avatar
i normally use Quaker state Torque Power 4x4 & truck full synthetic but for some reason that have stopped selling it around the house. i was wondering what everyonelse is using? i would like to keep using a full synthetic but with so many brands out there is any one better than the next?
Old Nov 26, 2009 | 08:52 PM
Norm's Avatar
How often do you change? If you change every 3 - 5K you can use any oil that meets Ford Specs. If you want to go longer you can chose the Motorcraft blend for up to 7500 or Amsoil's XL for the same interval. The XL also has the API starburst for those that care about that.
Old Nov 26, 2009 | 11:52 PM
Labnerd's Avatar
Pick a brand- yeah, it's that easy. Just see that it has the Ford spec on the back of the bottle and you can't buy a better oil. If you're changing at recommended intervals, synthetic buys you nothing but a lighter wallet. At one time, about 20 years ago, synthetics would flow better at cold start up and take a lot more heat. Those days are gone just like the Model T and leaded gas. Just pick a brand you like, use the recommended viscosity, change at the recommended mileage, don't pay a lot for it, sit back and enjoy the ride.
Old Nov 27, 2009 | 05:39 AM
risupercrewman's Avatar
MotorCraft Semi or Full Syn will do you good!
Old Nov 27, 2009 | 11:40 AM
RacingJake's Avatar
Just hit 130,000 miles on my 02 so it's time for it's 5,000 mile oil change with Motorcraft's 5-20 oil and 820 filter and I'm good to go until 135,000.
Can't beat 11 bucks for a 5 Qt jug too.
Old Nov 27, 2009 | 12:49 PM
BigBlue5.4's Avatar
Just avoid Quaker State! That stuff is like pouring sludge into your motor from the start.
Old Nov 27, 2009 | 09:18 PM
avfrog's Avatar
I never change oil brands or weight on a daily driver... Castrol 5w-20 every 3k
Old Nov 29, 2009 | 11:02 AM
JTDEERE's Avatar
Mobil 1 Full Synthetic 5w20 here. Every 5,000 miles.
Old Nov 29, 2009 | 11:06 AM
f150fella08's Avatar
i use valvoline high mileage 5w20 every 3k and a motorcraft 820s filter.
146k miles and still rollin with no problem
Old Nov 29, 2009 | 01:47 PM
str8t six's Avatar
i use motorcraft or mobile 1
Old Nov 29, 2009 | 01:49 PM
no-mams's Avatar
any synthetic should be good as long as you use 5w-20
Old Nov 29, 2009 | 02:50 PM
built54's Avatar
Mobil 1 Full Synthetic 5w20 here too
Old Nov 29, 2009 | 05:38 PM
MTM Ford's Avatar
I use Valvoline and nothing else.
