Clicking Noise
Old Nov 15, 2009 | 10:11 PM
karch23's Avatar
Exclamation Clicking Noise
I have a clicking noise that goes faster w/as i push the gas and slower when i let off the gas.. worse first thing in the morning. Is this my valves tapping? Someone said possible exhaust. Ford 150 V8 1997. Concerned.
Old Nov 15, 2009 | 11:04 PM
chiefFX4's Avatar
probably an exhaust leak where the manifold meets the head. get under the truck and see if you have any studs broken off.
Old Nov 16, 2009 | 08:59 PM
Layedout02's Avatar
yea a leak, it wont hurt it, but thats what it is
Old Nov 17, 2009 | 02:16 AM
It could be a loose spark plug getting ready to launch - I'd check that RIGHT away.
Old Nov 24, 2009 | 05:55 AM
J Foster's Avatar
I'd say PCV valve(s). $5 part. feel them or pull one off while it's running and see if that's it. If you take it off with the engine running you'll have a big vacuum leak so cover it with your finger.
Old Nov 24, 2009 | 11:09 AM
DYNOTECH's Avatar
All good ideas above but if it was me the first thing I'd do is remove the serpentine belt and see if the noise stopped. If so then you may have a bad FEAD component (Alternator, A/C, P/S, belt tensioner, pulley, etc.) More than likely one of the above ideas like exhaust are correct but in the process of elimination this is a good/easy place to start. Good luck
Old Nov 24, 2009 | 03:21 PM
jbrew's Avatar
Right and take off your watch as well
