Intermittent rough/smooth idle
Old Nov 15, 2009 | 02:52 PM
Kellxr7's Avatar
I havent owned my 05 F150 for very long so I am still working out its bugs, but it had what I would call a rough idle compared to what I was used to with my ranger. I cleaned the maf sensor and noticed an improvement, but its strange because I will stop at the lights and it will runs completely smooth, next light, a little rough... etc. Its seems hit and miss, but noticed its a little more rough when its in park or neutral as opposed to in gear with a foot on the brake. To add to this, I dont know if its technically what I would call a "rough" idle, it almost seems to very mildly shake with a rhythm. Spark plug cutting out? I know its time to change them, but I am waiting for a hand from a ford tech buddy with proper tools incase they snap off. Would a bad plug be a possibility though?
Old Nov 19, 2009 | 11:46 PM
ridinmudddy's Avatar
i had the EXACT same problem. i changed out the spark plugs and boots and it completely fixed the problem, then a few weeks later it got a little bit rough again. its strange. i cleaned the mass air flow sensor and that made a big improvement too. hope this might help
Old Nov 20, 2009 | 12:39 AM
rabbit hunter's Avatar
I have the same problem with mine. Sometimes is smooth as silk, others it almost dies. I've searched over this forum alot on this subject and it seems alot of others have the same problems with no solutions.
Old Nov 20, 2009 | 01:26 PM
AZTriton's Avatar
Wasn't it the '05's that also had problems with the injectors? I believe there is an extended warranty offered by Ford because of the issues with the injectors. You might want to check that out. Also make sure your fuel filter gets changed every 15k miles.
Old Nov 20, 2009 | 01:58 PM
SoCalF150FX4's Avatar
If you cleaned the MAF and noticed improvement, try cleaning the throttle body. Its an easy problem solver. My 06 did the same thing. Pulled the throttle body it had a bunch of black carbon build up.
Old Nov 20, 2009 | 02:17 PM
Matts ford's Avatar
yup the 05 5.4.
what engine? mileage? anything else been done lately besides cleaning the maf? i would also suggest looking into pcm updates for your truck.
Old Nov 20, 2009 | 03:51 PM
Pete Ferger's Avatar
Same problems here, had lots of work done on 2001 F150 last year. Now repeating same spurting, skipping, when idle. Told by two seniors that normal for F150, just put rubbing acohol in gas and should clean out problem.
Anyone ever heard of this?
Old Nov 20, 2009 | 11:31 PM
Nope, because 70% isopropyl (rubbing) alcohol contains 30% water. If you are going to put alcohol in the gas, use commercially available gas line antifreeze (Iso-Heet).
Old Nov 21, 2009 | 11:36 AM
DYNOTECH's Avatar
What brand of sparkpluga are you guys using?
Old Nov 21, 2009 | 12:45 PM
greencrew's Avatar
My 08 with 11k does the same thing. Sounds like it's running on 7 cylinders. I park it, and then it runs fine next time.
Old Nov 21, 2009 | 02:11 PM
i use nothing but motocraft. i am about to change out the fuel filter. and im just gonna go ahead and throw 4 new o2 sensors on when i put my headers on. oh i forgot to say when i cleaned the maf it made a big difference but it still doesnt idle right for some reason.
Old Nov 22, 2009 | 12:55 AM
Don't waste your money on new rear O2 sensors - all those do are monitor catalyst efficiency and do not affect the way it runs in the least bit.
Old Nov 22, 2009 | 01:50 AM
oh okay well thats good to know thanks man
