Truck Won't Turn over
so i got a custom tune that took the pats off and everything...Put the key in turn it you can hear the fuel pump go off...and then nothing...the truck is pulling this code...P1232 Fuel pump speed primary circuit malfunction...what causes this to happen and could this cause the truck not to turn
So, you don't have the PATS key then?
I'm not familar with the PATS setup, but my guess is that there is some other piece to the PATS system other then the computer that is acting as a secondary 'check' of some sort??
Sorry I can't be of anymore help....
Mitch
Mitch
Do you know where the starter solenoid switch is? If you do short the two exposed terminals. The starter should turn the engine over. be sure it is in P or N.
Does it turn?
Does it turn?.
