Check engine light...truck rattles a bit on acceleration..
check engine came up
2005 f-150 lifted with 91K miles
i noticed that when i get on the freeway at a steady speed the truck is FINE
but when i start to slow down at around 45, and i SLOWLY speed up, it would start to shake a bit, right before hitting the 2,000 RPM, when it passes the 2K rpm the shaking stops..its like a small back n forth back n forth
any ideas? im going to a shop on friday, but im curious to know what may be the problem?
I don't know if its just here in cali or what, but they passed a law couple months ago that those places can't do those anymore lol
but yea, im going to get the codes on friday, i was just hoping someone might have a slight idea on what the problem was..thanks guys
You can thank the mechanic's union in California for that law. Buy your own scanner off Amazon.com for about 40 bucks.
http://www.amazon.com/Autel-MaxiScan...3808842&sr=8-3
With 91k, you are ready for new spark plugs and maybe one or more coils. You probably have a low grade misfire, and you will probably pull some P03xx codes.
got the codes checked, friend who works at kragens just gave me the scanner to do it myself..got a code P0306 and will replace it tomorrow when they get the part in..ill def be looking into getting new spark plugs
What part though? Code P0306 is a misfire on cyl 6, but that doesn't really pinpoint the problem. Could be wires, plugs, injectors...
