rattle when under pressure
Old Sep 20, 2009 | 06:18 PM
F150man21's Avatar
ok so i was driving my truck on a 300 mile trip and i noticed that when i stepped on the peddle and it did not jump a gear that you would hear a rattling noise. i have noticed it before but its getting louder now and happening more often. i looked under the truck and theres nothing loose. this rattle happened before i changed my plugs and after so its not a spark plug knock, but i still have no clue what it could be and theres no power loss either. also its a 2000 f150 5.4 86k.
thanks
Old Sep 20, 2009 | 06:20 PM
Matts ford's Avatar
check the exhaust heat shields.
Old Sep 20, 2009 | 07:37 PM
F150man21's Avatar
yea i did, they all seem pretty solid
Old Sep 20, 2009 | 08:31 PM
Matts ford's Avatar
what brand and type of oil do you use? and what oil brand filter? does it matter what octane gas you use? do you know where its coming from?
Old Sep 21, 2009 | 12:21 AM
F150man21's Avatar
valvoline 5w30 full syn, motorcraft filter, not sure, and it sounds like its coming from right in front of the drivers seat.
Old Sep 21, 2009 | 12:27 AM
It could be spark knock (detonation). Try a tank of premium gas, does it go away?
Old Sep 21, 2009 | 11:00 PM
Andy-jr.'s Avatar
It might be your cats. Mine does it only when I am at a dead stop and step on it pretty hard. That's what it was on mine, hope that helps.
Old Sep 24, 2009 | 10:21 AM
F150man21's Avatar
tried the premium gas and it worked, no more annoying noises. so what do i do next, seafoam? what do you guys recommend?
Old Sep 24, 2009 | 12:21 PM
I'd spend the 75 bucks for a Motorvac or BG intake cleaning job. Doesn't hurt to do one every so often anyway, I had one done at 84k. You could try a bottle of Techron in the gas and see if it helps enough to stop the ping. Another option is to try different brands of regular gas. What you have are combustion chamber deposits, raising the compression, and also creating localized "hot spots".
Did you use Motorcraft plugs?
Old Sep 24, 2009 | 12:59 PM
F150man21's Avatar
yes i did
Old Sep 24, 2009 | 01:05 PM
F150man21's Avatar
and will seafoam do the job?
Old Sep 24, 2009 | 01:35 PM
Seafoam in the gas tank won't do much at all, Techron is just as effective if not better. Pouring it down the brake booster vacuum line has dangers involved, such as dumping it in too quick and causing a hydrolock. I would REALLY recommend the Motorvac or BG job, because that also cleans the throttle body.
Old Sep 25, 2009 | 10:01 AM
F150man21's Avatar
what's a BG job?
Old Sep 25, 2009 | 11:49 AM
It's where they hook a machine up to the intake and run the thing on chemicals. Most Ford dealers have either a Motorvac or a BG machine, as do a lot of independent shops. Motorvac and BG are essentially the same thing.
Old Sep 25, 2009 | 01:41 PM
F150man21's Avatar
thanks glc, you've been a big help
