Any Ideas? Check Engine Light.
She can't breath, - needs an air filter most likley..
i found this site you may wanna look at tells you all about that code and how to go about fixin it http://www.obd-codes.com/p0506
how many miles? may try cleaning the throttle body first then disconnect the battery for about 30 min to reset the computer\
Yea , it's a sure bet that TB is dirty. Your using a junk filter for that truck , that's no way to treat it. Better clean the MAF while your at it, -since you thru a oiled element in the intake = bad move IMO. Run your hand inside the intake, feel all that sand/dirt that gets past that filter? Try it.
No I dont have an edge tuner
