Battery Light flickers when revving over 4k
Yesterday while pulling my Holiday trailer I experienced an interesting thing in the truck. Going up a hill with the trailer (4000lbs) the revs went over 4k and the charge light came on intermittently. I figured that this was due to the trailer there and the charge line on the trailer being used etc. However, the same thing happened to me while just driving the truck. Does this mean my Alternator is on the outs? any thoughts?
Thanks in advance.
Thanks in advance.
Is it a 130 amp or 90 amp? I would go for the 130 if buying new.
There are "brushes" also known as rotator contactors that conduct power to the Rotator Field Coil.
At the last term of life of the alternator they have worn down so low that they don't make sufficient contact with the contactor rings.
This is particularly true at high engine rev speeds. Remember your alternator is spinning at three times the engine r/m. (minimum)
It is just the last sign that your Alternator needs replacement.
There have been times that I could "re-furbish" a similar unit if I could get similar brushes and place them into the alternator. Unfortunately it's messy work and considering an available warranty I would replace that unit a.s.a.p.
