Need Help
Old Aug 12, 2009 | 12:01 AM
NawwMann772's Avatar
From: Raised In Hobe Sound, FL. Now Stationed In Kings Point, NY
Need Help
ok so on my way home my check engine light came on. i had a buddy run the codes, it came up a p0174. does any body know what code that is or has had this problem before and fixed it? when i get on it a little bit to pass someone the engine sputters a bit, like it isnt getting enough fuel or some **** like that. i could use some help please. 2004 5.4 4x4 screw
Old Aug 12, 2009 | 12:08 AM
Matts ford's Avatar
p0174 is lean bank 2.
is the truck a new body? or old body heritage edition? whats the mileage? do you have an aftermarket cold air intake? do you have an exhaust leak on the driver side? was there a p0171(lean bank 1) code with it? how olds the fuel filter? has the maf ever been cleaned? i'd change the fuel filter and check fuel pressure first.
Old Aug 12, 2009 | 01:53 PM
Matts ford's Avatar
got your pm. try to keep the info in this thread that way everybody can view it and try to help.
Yes The Truck is a new body, the miles currently are a couple hundred over 80,000. No the truck is bone stock, and no i do not have an exhaust leak. No P0174 was the only code that it was reading, as far as fuel filter age, and maf being clean im not sure. i just bought the truck about 2 months ago from a dealership in my town. im only the 2nd owner and as far as i know the previous ower had taken it to get all the scheduled maintence when it was due. i very much appreciate all the info and help.
sounds like it could be a intake manifold seal leaking or an injector(s) may be plugged or restricted(or not opening)- or possibly the sensor itself but generally when they throw a code it means they are working(for the most part). is it idling rough? or is the cel and sputtering at high rpm's the only problems that your noticing? i'd have the injectors tested because if they are restricted or not opening properly at high rpm's then it can cause a misfire/lean problem.
Old Sep 10, 2009 | 08:43 PM
Ok sry its been so long since ive said anything. when i cleared the code with my buddies reader( bout 3 weeks ago) the code hasnt shown up again yet. the people the engineer's im stationed with are sure that its just an 02 sensor. im replacing it in a week when i get paid
Old Sep 12, 2009 | 11:53 AM
I highly doubt it's a bad O2 sensor - it's doing its job REPORTING a lean condition.
