4.6 help
Old Aug 29, 2009 | 01:07 AM
medic299's Avatar
4.6 help
I am in the process of switching motors and need to use my intake. When i took the lower intake off to clean it, all of the material inside of the rubber covering was dust. The rubber was dry rotted as well. What is the reason for this stuff and where does one purchase a replacement. Thanks in advance for any help. DV
Old Aug 29, 2009 | 06:20 AM
phil6608's Avatar
I looked on ebay and they have mostly mustang manifolds but I found 2 for truck.
I don't think the second one will work but you can probably use the older aluminum one. Maybe.
Otherwise try a junk yard or the dealer.
http://cgi.ebay.com/ebaymotors/Ford-...Q5fAccessories
http://cgi.ebay.com/ebaymotors/FORD-...Q5fAccessories
Phil
Old Aug 29, 2009 | 06:25 AM
jbrew's Avatar
Old Aug 29, 2009 | 06:26 AM
jbrew's Avatar
Old Aug 29, 2009 | 06:28 AM
phil6608's Avatar
Originally Posted by jbrew
Fix that Jbrew!!!!!!!!!!!!!!!!
Old Aug 29, 2009 | 06:29 AM
jbrew's Avatar
lol - Hang on , I'm still laughing
Old Aug 29, 2009 | 06:32 AM
jbrew's Avatar
Yea, I figured I better hang out awhile lol.
Now everyone is going to wonder what happened lol.
Old Aug 29, 2009 | 06:33 AM
phil6608's Avatar
I sent that to my girlfriend yesterday...lol I was warming her up for this weekend.
Thanks for noticing and fixing it.
Phil
Old Aug 29, 2009 | 06:40 AM
jbrew's Avatar
Phil
What a surprise, - I was expecting some boring manifold pic
That woke me up a bit lol.
Old Aug 29, 2009 | 12:04 PM
ONELOWF's Avatar
I believe that material is a sort of insulation blanket? I don't have it in my truck since the intake swap, and it seems fine after 20k miles.
Neither of the ebay manifolds would be correct. The first one is Npi, which would work, but not be a good port match, and the second one is for a 3v engine.
Try the junque yards, but be specific. Some of the accessories need the exact bolt holes in the manifold to relocate correctly.
Old Aug 29, 2009 | 12:34 PM
Matts ford's Avatar
that second pic is for an 04+ 4.6 2v with the updated spark plug threads and drive by wire.
Old Aug 29, 2009 | 04:58 PM
medic299's Avatar
ummmm i have two complete intake manifolds to include upper and lower, my question is the rubber and containing insulation is shot on both lower intakes. Do i need to replace the cover and insulation?
Old Aug 31, 2009 | 03:08 PM
jbrew's Avatar
I'm not sure what's that's for. - I still use it, - ONELOWF runs without and no problems.
BTW- It's called a jacket- mines just solid rubber w/snaps.
It's rubber so mabe it's something to help with with heat and moisture - just guessing. Personally , I would replace it if I could locate one.
Old Aug 31, 2009 | 03:54 PM
JMC's Avatar
JMC
25 Year Member
Are we discussing #20?
It is a NVH (Noise Vibration Harshness) shield. Mine is long gone.
Old Aug 31, 2009 | 03:57 PM
JMC's Avatar
JMC
25 Year Member
Regards
Jean Marc Chartier
