Help 5.4l in 01 lariat choking out!
Old Aug 22, 2009 | 09:23 AM
radnac2001's Avatar
Hi I have an 01 lariat that has a problem When Istart it for the first time of the day no matter what time it will stall. You have to keep on the gas to keep it running after that it will start all day no problem. It has also started to hesitate at cruising speeds when you accelerate. Plugs, cops, and wires replaced about 15000 ago only mod is k&n air filter and flowmaster cat-back duals. truck throws no CEL any help would be appreciated
Old Aug 22, 2009 | 10:51 AM
K-Mac Attack's Avatar
I would look at changing the fuel filter first.
Old Aug 22, 2009 | 03:15 PM
jethat's Avatar
air & fuel filters..
Old Aug 22, 2009 | 04:59 PM
d_dyer's Avatar
My dads truck is a 00 and had the same problem, No CEL light was glowing but i still pulled the codes and it had a bad fuel pump relay, May be different for you but it is worth a shot.
Old Aug 26, 2009 | 01:53 PM
tennfan1's Avatar
check IAC for carbon buildup. Caused my starting problem, very intermittent. Eiterh take it of and clean it or replace it. On the back of the throttle body held on by 2 10mm bolts, use throttle body cleaner to clean the spring and valve.
TF
