injectors
Old Aug 11, 2009 | 05:13 PM
fullyford's Avatar
injectors
now that i have my new motor in...i have an apointment to get it dyno tuned on Aug 20th....the mustang donor motor came with pink injectors and from what i have been able to find is that they are 21lb injectors...so would i benefit anything by putting these in over the yellow 19lb injectors...does anyone know for sure if the pinks are 21lb
Old Aug 11, 2009 | 07:05 PM
jbrew's Avatar
19's are Orange
Injector Lb/Hr---Max V8 HP --------Ford Color*
14 Lb/Hr------------228----------------Gray
19 Lb/Hr------------310---------------Orange
24 Lb/Hr------------391---------------Lt Blue
30 Lb/Hr------------490-----------------Red
36 Lb/Hr------------587---------------Dk Blue
42 Lb/Hr------------685---------------Lt Green
60 Lb/Hr------------800
*Colors are only constant for Ford Racing Performance Parts brand name injectors.
Old Aug 11, 2009 | 08:05 PM
fullyford's Avatar
too me it looks yellow
and this is a factory ford pink injector..from what i can find it came on the mustang in late 02 and up
but does anyone know for sure if it is a 21lb injector and would i gain anything by putting them in..i am getting a custom dyno tune and am just wondering if i would benefit anything
if those hp rating are correct i might be getting close to 100% duty cycle with the 19lb injectors..i am hoping to be in the 320+ hp but won't know until i am on the dyno what it is really pushing
Old Aug 11, 2009 | 10:33 PM
jbrew's Avatar
Orange on Top, but yea looks like Hot Pink on the bottom lol. It's probably suppose to resemble Red.
Google the Part number or thro the Part# in @ ebay motors SrchBar. Should be able to confirm.
http://cgi.ebay.com/ebaymotors/Musta...s#ht_500wt_924
http://cgi.ebay.com/ebaymotors/Musta...#ht_2353wt_681
lol -
http://cgi.ebay.com/ebaymotors/Ford-...s#ht_500wt_924
I don't know ? Part# look-up comes back with 0. I think their 30's, but the numbers don't match.
Old Aug 12, 2009 | 01:19 AM
fullyford's Avatar
even the mustang guys are fighting over the pink injector some say 19 some say 21.5...some say yellow some say orange is 19..heres a link i found to a good debate..but know one has a solid answer..not sure where else to take this and ask....
http://mustangforums.com/forum/4-6-m...injectors.html
Old Aug 12, 2009 | 01:35 AM
fullyford's Avatar
i think i found my answer according to this video they are 22 lbs
http://www.youtube.com/watch?v=Emnax...layer_embedded
Old Aug 13, 2009 | 07:52 AM
jbrew's Avatar
I read that other stuff in the Mustang Forum last night, - Yea, I see where it's confusing as hell. Some say Pink =19's (very few), One seller on Ebay was selling Pink Mustang injectors as 19's. The Majority sticking with F0TE-D9B, 22#, jetronic; "Pink Top" 21-22 lb'ers.
I found the Part number on Fords (Motorcraft) Part # PDF sheet. Go here if you need a part number for anything -
http://fordfzone.com/forums/index.php?showtopic=3414
It's on page # = 469 - Here's the PDF itself - ( http://www.fordinstallersupport.com/...ogs/fes200.pdf ). BTW- You might have to download/save to desk top first/ then open is seperate operation for it to work.
CM-5041
Fuel injector
(F0TE-9F593D9B)
PASSENGER CARS
FORD & MERCURY .....................................2004-91
LINCOLN .................................................. .1994-91
LIGHT TRUCKS
FORD TRUCK .............................................2005-85
LINCOLN TRUCK ........................................1999-98
That's all I found on it - No spec,- which doesn't help much.
___________________________________
Old Aug 13, 2009 | 08:06 AM
jbrew's Avatar
Now that's a great find, - some interesting stuff right their. I run the type (design) 3's (third from the last in the vid) . I have been running those for 3 years or so and what I notice most is consistency. Doesn't seem to matter much , -city/highway, I'm always @ 15-16 mpg. It's not the best in the world , but it sticks. If I tried , I imagine I could jump up to 16-18.
I have to watch that vid again and write that Rail pressure down he tested at, -I think he said 37lbs. ? The Orange/Pinks flow about the same. BUT, if that's correct, that would make the Orange 19 lb'er a 21 or 22 lol.
I have to look at that again, but yea, -GREAT Link!
Old Aug 13, 2009 | 01:31 PM
fullyford's Avatar
he said hes running them at 43.5 lbs..something about ford rail being 37lbs
so do you think i will gain anything by putting the pink injectors in..they flow alittle more..not much...he says that he considers them both to be 22lbs..
Old Aug 13, 2009 | 03:36 PM
jbrew's Avatar
I probably wouldn't use them personally. Well it would depend on what PCM I was using , unless it's getting tuned. The Orange 19's (Type 2's and 3's ) put out about the same flow rate as the 22's, that's what's throwing me, a little -right now anyway. What intake are you using ? Truck or Car?
I would have to investigate more myself, specially now. RIght off- Here's a good one pager with some good "Injector/PCM" info, -of what you may be faced with if you stray from the original poundage without a tune -
http://fordfuelinjection.com/?p=9
Old Aug 13, 2009 | 06:09 PM
fullyford's Avatar
using a truck intake..it getting a custom dyno tune on the aug 20..i think i will take the injectors that way if i need them, then it just a simple swap to put them in
Old Aug 14, 2009 | 11:42 AM
Veteran: Army
I made decent power with 24# injectors, I gained like 15hp and a few ft lbs, you can always run 'em (after the ECM is tuned) since your getting tuned but if they are larger than 24#ers you'll max out your stock pump and run lean in the higher rpms
