5.4 shutter/shimmy/shaking??
i wrecked my truck a few months ago and just got it back together this past saturday
while i was driving it i noticed at certain speeds in the rpm range(mainly 1300-1700) it will kind of shutter and shake the truck...it only does it at certain speeds with that rpm and sometimes doesn't do it at all...when it starts doing it if you hit the gas it comes out of it
i have the gryphon and was monitoring the spark, MAF, and engine load to try to see if something was wrong...but i really don't know what numbers are to be expected where
my spark was anywhere from 10 to 50, MAF was 10 to 160 or so when i really got on it
any clue what might be going on or what numbers to i should expect at a certain rpm/gear to check to see if everything is running right??
i don't have a CEL yet so i don't think its really major but it sure isn't how its supposed to be
for what its worth i have a 98 scab f150 4x4, with the 5.4, with a K&N CAI, gryphon, and a dumped dynomax bullet single exhaust
thanx
thanx
good luck
ps i only said change the COPS because if you change the plugs you usually change them to but you already did.
thanx i get what your saying...the engine compartment was pretty dirty so i doubt they washed it but hell i guess it would be worth a shot to change them out anywayz...can't hurt anything i guess
autolites
ikik supposed to run motorcrafts...found this site about 3 days after changing all my plugs
would they cause that after only around 7-8K??
i already use the wix napa gold series...i should pry change my fuel filter to...it almost acts as if its bad gas at times
most likely do that first as i really only want to change plugs as a last resort
well im still kind of investigating...i think i may have jumped the gun when thinking it was ignition/fuel/spark/motor related...im thinking it might be in the suspension know...its hard for me to tell unless im on the highway because the gravel roads are so bumpy you don't know what is what
hopefully i'll get the fuel filter changed this weekend and take a closer look at the front suspension and maybe figure it out...i figure as long as i don't get a CEL its not to serious if it is with the motor
