I broke something and don't know what it is
Old Jul 27, 2009 | 11:37 AM
Aggie'98's Avatar
2002 F-150 5.4L 4X4 KR. I'm trying to find/repair a vacuum leak that is causing me some minor A/C problems and in the process I broke something that I can't identify. It's located above the master cylinder and has a 3/8" or 5/16" vacuum hose running from it to the back of the throttle body. I was trying to remove the vacuum hose when a plastic elbow broke off.... I plugged the vacuum hose but don't know what to do with the black/green unidentified part. Truck runs fine. Looking at the vacuum hose diagram it looks like it might be the evaporator service port. Can anyone help?
Old Jul 27, 2009 | 11:56 AM
ONELOWF's Avatar
Ouch. That is the EVR, electronic vacuum regulator for the EGR system. This may require a trip to the dealership with your vin in hand to get the correct one?
Old Jul 27, 2009 | 12:53 PM
poolboy1191's Avatar
Yes, the EGR valve is only available at the Dealership. It won't effect the run unless you are in COLD temps.
I had the same problem.
Old Jul 27, 2009 | 03:34 PM
Aggie'98's Avatar
Turned out to be the vapor management valve...... $75 at the dealership. I probably could have lived without it, but I'll sleep better at night with it in there.
Old Jul 27, 2009 | 03:51 PM
I just noticed again that you are in Longview. I grew up there and still have folks around town. Was over there 2 weeks ago.
Old Jul 27, 2009 | 06:50 PM
jbrew's Avatar
Wow , $75 for that part
Well, yea, you did the right thing for sure. I've broke quite a few of those. - It sucks because that little plastic tube breaks off flush with the solenoid, leaving you with no way to fix.
I was fortunate enough to find them sold in bulk on ebay for $9 apiece. They come in handy lol.
Although this doesn't help you now, I would have done the same thing given the circumstance, - but mannn, their sure not cheap at the dealer.
Old Jul 27, 2009 | 06:52 PM
f150fella08's Avatar
longview eh? im about a hour away from you
