99 F-150 Fusible Link problem
Old Jul 25, 2009 | 12:06 PM
wpack's Avatar
Ok, I have a 99 f-150 with 214k, the truck broke down on Tuesday night, the cause was the fusible link, i replaced it this morning & when i put the battery terminal on, it smokes, what would cause the fusible link to melt in half ?
Old Jul 25, 2009 | 12:12 PM
Matts ford's Avatar
which fusible link? motor? did you hook the battery up right? the fusible link is made to burn up when it gets too hot, that way it doesnt destroy the rest of the circuit.
Old Jul 25, 2009 | 12:39 PM
wpack's Avatar
The fusible link from the battery to the solenoid & starter, i have the battery post correct, any ideas ?
Old Jul 25, 2009 | 01:03 PM
Matts ford's Avatar
ok did you get the right fusible link? or did you just get a roll of universal fusible link? make sure the starter solenoid/relay on the firewall isnt stuck sending power to the starter.
Old Jul 25, 2009 | 01:29 PM
wpack's Avatar
I took a old one off a old truck & replaced it, also replaced the ground from the firewall to the motor, still no luck, any more ideas ?
Old Jul 25, 2009 | 01:31 PM
Tumba's Avatar
Sounds like the solenoid stuck, and then burned the starter up, then cause the fuseable link to burn.
Old Feb 4, 2017 | 07:52 PM
TENNO89's Avatar
Wher is tht fusible link located???
