First plug change, advice please
Old Jul 20, 2009 | 09:47 PM
V1supercrew's Avatar
I'm replacing my intake, thought I would catch the plugs with the manifold off.
Went to NAPA and got autolite XP 103s.
Before I put these in, are these OK? or can some recommend a sure thing please.
engine is a 5.4 in a 2001 supercrew
Old Jul 20, 2009 | 10:22 PM
Take them back and get Motorcrafts. Install them DRY with NO antiseize and torque them to 28 ft/lb. Use adequate dielectric grease in the COP boots when reassembling.
Old Jul 20, 2009 | 10:37 PM
no special type plug, just the standard motorcraft plug that is in the look up for a 2001 5.4 right?
Thanks for the torque spec, I'm not that familiar with aluminum heads
Old Jul 21, 2009 | 05:02 AM
jbrew's Avatar
Yes, - return the 103's. Here's the part # your looking for~
MOTORCRAFT SUPPRESSOR SPARK PLUG -- Delivers maximum voltage to the spark plug while maximizing performance and increases engine life; Resists corrosion and abrasion; Reduces the chance of misfire.
Fit Note: .054 Gap; Platinum.
Type: Direct Fit OE Replacement
The 2001 F150; 5.4L =
Manufacturer Number: SP479
Old Jul 21, 2009 | 08:48 PM
jerrycranium's Avatar
No Anti-seize on plugs?
GLC's replay that said not to use antiseize and install the plugs dry. Why is that? Wouldnt you have the same problem here as plugs seizing in the head? Maybe why so many people report having plugs break off in the head.
Old Jul 21, 2009 | 08:56 PM
Tumba's Avatar
Some engines will blow the plugs out if you use the anti seize. That stuff is just so slick, there is just not enough friction to hold them in place
Old Jul 21, 2009 | 09:47 PM
Well the plugs are done. This is my first aluminum head.
I used a beam torque wrench to break the plugs loose, every one was just short of 30ft lbs. I blew out the holes with compressed air before removing the old plugs, reinstalled each SP479 plug with a small hose and torqued dry to almost 30 ft lb.
Original plugs had almost twice the recommended gap at 150K miles. I'd hate to have to do this task with the manifold in place ( cracked last week )
Thanks to all, for a helping hand on this project.
Old Jul 21, 2009 | 11:51 PM
Tumba, thanks for the info. I have seen complaints with the 5.4 blowing plugs out but did not understand how that could happen. I just bought a 04 Lariat today and am nervous about changing the plugs. Its got 75000 and i wonder if i should attempt it sooner than later. Would hate to bust one off in a truck i just bought.
Old Jul 21, 2009 | 11:56 PM
The blow out problem is with the 2v engines up thry 2003. You have the 3v and need to be concerned with the brakage problem. Just follow the TSB and if one breaks, have the tools handy for removing. Do a search on the subjects for lots of info.
Old Jul 22, 2009 | 04:31 AM
Jerry, the reason I said what I did is the 4.6's and 5.4's through early 2003 only had 4 threads in the head. Plugs torqued to factory recommended 15 ft/lb with antiseize had a nasty habit of loosening and blowing out. The Motorcraft SP-series plugs have nickel plated threads, which eliminate the need for antiseize, and torquing them to 28 eliminates the loosening problem.
Now, your 3V is a whole different story, you have a lot of threads to read.
Old Jul 22, 2009 | 10:01 AM
Norm's Avatar
Not quite true. Anti seize just changes the torque value required and most people do not know how to calculate the correct value so they are safer using none and tightening to the dry torque value. Anti seize does not cause blow outs, incorrect torque does.
Old Jul 22, 2009 | 12:13 PM
I am going on the recommendation of the guys at blownoutsparkplug.com. I specifically asked them about antiseize, and they say NOT to use it on the 4 thread heads.
Old Jul 22, 2009 | 01:31 PM
Norm's Avatar
That is the safest recommendation.
Old Jul 22, 2009 | 02:25 PM
jbrew's Avatar
I have to say, I've never seen a anti sieze torque spec lol.
Norms right tho -
"Question:
Do you torque spark plugs differently with anti-seize compound on an aluminum head engine?
Answer:
Yes, anti seize can affect torque specifications by as much as 30%, depending on how it is applied. If there is a torque range, say for spark plugs like 15 - 21 ft lbs, then torque to 15ft lbs and you can rest assured the plug will be driven deeper than it normally would have at 15 ft lbs without anti-seize."
It is SAFER to go without. This question an answer explains the simple reason why; how easy it is to OVER- torque and not know you doing so.
__________
On another note, my plugs didn't come with specs, nore did they say to use anti-seize, BUT they did come with directions. They directions were in 90 degree "turns" after seat.
That said,-they still came out to around 20 ft lbs.
