Start problems
Old Jul 15, 2009 | 07:46 PM
jbrew's Avatar
Originally Posted by tennfan1
Cleaned IAC valve, not too cruddy but looks better now. Time will tell. Thanks glc, Jbrew, jethat for the help. If this does not fix the problem I will update.
TF1
Doesn't really matter what she looks like, she just has to work lol.
Yea, when you clean them , you have to work the mechanicals (plunger inside) inside while doing so or it won't matter. It's what gets stuck.. -That plunger has to work or she won't idle. Hence ~ IdleAirControler (IAC).
BTW- Seafoams~DeepCreep works the best to remove carbon, lube and is sensor safe. Harsh cleaners eat em up.
Old Jul 16, 2009 | 01:00 PM
tennfan1's Avatar
I agree, cleaning is only good if it works otheriwse you end up with a pretty valve, not one that works. I used a "rubber safe" cleaner due to the diaphram that is on one side of the piston. There is not a lot of travel on that piston so you had to make sure that you got everything cleaned up and did not leave carbon in the holes. Since cleaning I have had 4 starts with no issues, when I go to get in it to go home will be the test. She has always idled fine just recently has had start issues.
TF1
