How much CFM???
Old Jul 17, 2009 | 02:28 AM
phil6608's Avatar
Originally Posted by Stephen87
But the other one is nicer
NO,
the Troyer fan is way way nicer.
And you shouldn't be running a 160 thermostat in these truck,,,I don't car if it's 140 there.
Old Jul 17, 2009 | 02:33 AM
Stephen87's Avatar
I see so 180 should be the lowest I should go, and with the 160 does that hurt the engine or does it just not let it heat properly
but in other news I think I am going to get the troyer e fan just as soon as I get a job
EDIT:
read into it and found out that it hurts performance and fuel milage by confusing the computer and causing the fuel mixture to run all screwy so it looks like I need to go to the dealer tomorrow and get a new one
Old Jul 17, 2009 | 02:59 AM
phil6608's Avatar
Yes these truck run better and more efficiently at a higher temp.
And the Troyer fan is $125. cheaper.
If you do get one.It will come with 2 ways to mount it.
1- is the things that push through your rad.(you do not want to mount it that way!)
2- are metal brackets that go over the top and under the fans.(that is the best way to mount it).
Phil
Old Jul 17, 2009 | 03:25 AM
Stephen87's Avatar
Sounds like a plan, and also thanks for the info.
Old Jul 17, 2009 | 04:36 AM
Run a stock 192 T-stat or it may not go into closed loop - it will run super rich and get awful gas mileage. It's NOT like the old days!
Old Jul 17, 2009 | 12:25 PM
Stephen87's Avatar
that could explain why I am running rich right now
