fan clutch
Old Jul 8, 2009 | 06:18 PM
timwithaford's Avatar
fan clutch
if im standing at the front facing the engine which way do i loosen need help
Old Jul 8, 2009 | 06:44 PM
f150fella08's Avatar
hold the fan and turn the wrench to the left
Old Jul 8, 2009 | 07:23 PM
fan spins its got that clutch there
Old Jul 8, 2009 | 07:29 PM
how do i stop the pulley on the water pump from spinnin is there a trick or just wedge a screwdriver in there an reaf on that shaft nut
Old Jul 8, 2009 | 08:24 PM
jbrew's Avatar
No
Run up to Auto Zone and grab their Fan wrenches - It's free to borrow them.
Old Jul 8, 2009 | 08:34 PM
Tumba's Avatar
I use the bolts that hold the pulley to the water pump, I back them out just enough to get a boxed in wrench behind the head of one, and the shaft of the wrench behind the other one. Then I put the big wrench on the fan shaft and give it a good twist. But I do let it soak in marvel mystery oil or similar penetrating oil for a couple of hours first. Those things can be a biech.
If I bend one of the small bolts, I go through the scrap bin
Flame suit on
But it does work!
Old Jul 8, 2009 | 11:56 PM
jbrew's Avatar
Flame suit on
But it does work!
What's to flame ? That's how you do it. The Ford, Clutch Fan kit does the same thing. The Large wrench fits over the pulley bolts. The other wrench fits the nut.
_________________________________________
But yea, sometimes it doesn't matter what you do, -she ain't budging! Sooo - I usually just get wizzed off and find another way ~
Old Jul 9, 2009 | 12:25 AM
fan clutch is standard thread
Old Jul 9, 2009 | 12:57 AM
jbrew's Avatar
Mine was, but I've heard sometimes their not. That's why I didn't want to say. I'm not sure on the 06 models - Are you ?
Old Jul 9, 2009 | 06:34 AM
Tumba's Avatar
I've got one of the waterpumps laying around somewhere, with the fan still on it. But it was secured on by a wreck in the red 98. I don't think it's coming off.
Old Jul 9, 2009 | 06:37 AM
Tumba's Avatar
My guess would be, that they are all standard thread, because the engine spins that way. But sometimes I figure wrong.
Old Jul 9, 2009 | 07:11 AM
jbrew's Avatar
That would be my guess, -now lol. I think I saw the possible reverse thread clause in the Ford Service removal procedure ? Ahh, I can't recall for sure tho.
I should pop in the DVD for the 06 and see what that one says. Maybe later.
BTW- Yea , you can bend bolts pretty easy trying to remove. - Funny thing is, when I install a new Ford fan clutch, I was surprised,-the required torque wasn't all that much.
Old Jul 9, 2009 | 08:13 AM
yes im sure all the ford trucks are standard thread.
I have personally taken off my 03, an 00, and a two 05s
some of the land rovers are reverse thread, its hard to remember what is what because they changed the engine manufacturers every 3 or 4 years, and even on a given year model, different model vehicles have different engines and manufacturers
Old Jul 9, 2009 | 08:44 AM
06 5.4 is standard thread.
Fan wrenches are knuckle busters. I just use an air chisle to loosen, on mine. Learned it from a good old gear head who works in our shop. He got sick and tired of wrenches slipping and cutting his knuckles. It don't take much to get it loose.
Old Jul 9, 2009 | 08:49 AM
they make a kit for attachment to an air hammer
they actually work very very well for stuck fans, but for the average auto enthusiast its not worth the investment of the expensive tools, the rented kits from autozone are effective, but can be a little dangerous
