Help on unbolting motor mounts and raising motor
Old Jul 1, 2009 | 03:17 PM
don40vette's Avatar
Does anyone have pics showing which bolts to loosen and where to place jack to raise motor? It's an 07 F150 2WD Thanks
Old Jul 1, 2009 | 11:23 PM
built54's Avatar
the motor mount bolts that run horizontal with the frame, 1 on each side. support the transmission with a jack or a strap around the frame
Old Jul 3, 2009 | 10:14 AM
JMC's Avatar
JMC
25 Year Member
If you lift the engine a bit it will take the weight off of the mount and make the bolt easier to unscrew and pull out.
