intermittent no start need help w/ this one
Old Jun 15, 2009 | 03:33 PM
kvnexpe's Avatar
2000 Expedition, 4.6, 4wd, 73,000 miles
Truck wont start sometimes after being driven for about 20 mins and then left off for about 20 mins, normal crank, no fuel at engine, fuel pump not coming on, get it towed once off tow truck starts right up as if nothing happened. Reproduced problem at home, only this time there was fuel at engine and could hear pump come on, would start but die immediately, left it for about an hour went to start same as before where there was no fuel and pump didnt come on, cycled key 4-5x times and started right up. reproduced again at home (a different day) checked for power at pump, when starts power at pump =13.5 volts when not starting power at pump = 9 volts. All relays/fuses are good, inertia switch is good, battery is good, No check engine light. Any suggestions????
Old Jun 15, 2009 | 04:25 PM
Have you changed the fuel filter?
Old Jun 15, 2009 | 05:34 PM
kvnexpe's Avatar
Fuel filters getting changed this weekend, was going to change filter w/ the pump but I'm not sure if its the pump or something else.....
Old Jun 15, 2009 | 05:49 PM
Matts ford's Avatar
does it have any kind of problems while your driving when it does start and run? are you using the factory key? security system problem maybe.
Old Jun 15, 2009 | 06:24 PM
jbrew's Avatar
One scenerial -
As soon as the pressure bleeds down , - she starts!! The rails over -pressurized. ~Check the regulator
BTW-The same thing happens when you crank the engine more than 5 seconds. - Shuts the injectors down. It's a fail-safe for the cats.
Old Jun 15, 2009 | 06:25 PM
srfd44's Avatar
The fuel filter wold be my first guess. You say all the relays are good which would be my second guess
I had the same symptoms (with a lot more miles though - 160000) and it turned out to be the fuel pump. Man I went through everything because I could not believe the pump could be good one time and bad the next.
Good luck with your problem.
Old Jun 15, 2009 | 06:51 PM
kvnexpe's Avatar
No driveability issues at all..original key, happens with both of them..I thought the same about the security system but no theft light and i didnt think the security would "reset" itself?
Old Jun 15, 2009 | 06:53 PM
jbrew's Avatar
Originally Posted by kvnexpe
No driveability issues at all..original key, happens with both of them..I thought the same about the security system but no theft light and i didnt think the security would "reset" itself? im hardly an expert tho.......
Do you know how to check the pressure? If not, just take it in and tell the dealership what it's doing.
Old Jun 15, 2009 | 07:00 PM
kvnexpe's Avatar
I know how to check the pressure, just gotta wait for my friend who has a gauge to bring it by.
Old Jun 15, 2009 | 08:06 PM
jbrew's Avatar
I would do that. I'm not sure where the relay is on the 2000, they changed the fuse blocks around quite a bit from model years. The relays are listed in that little booklet that comes in the glove-box when you purchased the vehicle. Anyway, you should be able to swap the fuel pump relay with the horn relay to determine whether that is the problem or not. Make sure they are the same, they are on my model.
Old Jun 15, 2009 | 08:39 PM
Stormsearch's Avatar
25 Year Member
Did you check the battery voltage under load (while engine not running)?
