Rough Idle
Old Jun 11, 2009 | 03:09 PM
MbA0069's Avatar
Rough Idle
Hey guys,
I got an '03 Lightning, it's got about 70k miles on it. Lately, when idling, the needle bounces a little between about 500 RPM, and 1000 RPM, and almost feels like its about to sputter and turn off, but it never actually does. After it sputters for like 4-5 seconds, it goes back to normal idle and it usually wont do it again for a few minutes.
I mean, It's not really a big deal the truck runs fine and it NEVER turns off, im just curious as to what could be causing this?
I checked for vacuum leaks, am good there. CAI Intake is less than 6MO old, and the TB is remarkably clean.
Mike
Old Jun 11, 2009 | 03:27 PM
jbrew's Avatar
Try the IAC Mike
Old Jun 11, 2009 | 03:46 PM
MbA0069's Avatar
Does it normally go bad after a while? I know it's fairly easy to replace, but still.
Old Jun 12, 2009 | 09:38 AM
F150man21's Avatar
if you haven't changed the OEM plugs yet i'd start to think about that.
good luck
Old Jun 12, 2009 | 01:25 PM
jbrew's Avatar
Well, they can corrode inside from moisture thru the PCV system and hang/ get sticky.
You can service it yourself w/ deepcreep or wd40. Remove it,- flood the sensor with on or the other solvents and work the mechanicals carefuly, then blow it out with compressed air.
Or just by new.
Old Jun 12, 2009 | 03:52 PM
MbA0069's Avatar
I'll try cleaning it first. Thanks.
Old Jun 12, 2009 | 04:29 PM
jbrew's Avatar
No Problem.
Old Jun 12, 2009 | 05:04 PM
MbA0069's Avatar
I wonder if its got anything to do with my latest Seafoam treatment. Seems its started the same day.
Old Jun 12, 2009 | 05:50 PM
jbrew's Avatar
To late now but, Seafoams just bad news, - don't do that to your truck.
Old Jun 12, 2009 | 10:41 PM
The only place Seafoam should touch your truck is in the gas tank. It's a decent injector cleaner.
