what is this?
Old Jun 7, 2009 | 02:26 PM
jhedges15's Avatar
what is this?
got back from mudfest yesterday and found the wires coming off of it melted into two pieces cuz it got jammed up against a header tube.
the two wires connected into a three prong plug along with a vacuum hose that came from the front axle. it leaked out gear oil all over the place. anyone know what it does?
Old Jun 7, 2009 | 02:33 PM
kingfish51's Avatar
Those are the solenoids that send vacuum to the vacuum motor on the front diff to lock and unlock it. Can't remember which one does which.
Old Jun 7, 2009 | 02:45 PM
jhedges15's Avatar
alright thanks. nothing to big to worry about then. just soldering the wires back together and its an easy fix
Old Jun 7, 2009 | 04:29 PM
kingfish51's Avatar
Make sure the vacuum lines did not melt, otherwise no 4x4.
Old Jun 7, 2009 | 06:06 PM
jhedges15's Avatar
Yeah I know. It didn't. It just came loose and spilled out some oil. I plugged it back in and that line isn't damaged at all
Old Jun 7, 2009 | 07:01 PM
kingfish51's Avatar
Vacuum lines would not leak oil. Sounds like your breather is what came loose. In which case, you may have sucked in some water and mud to the front diff.
Old Jun 8, 2009 | 01:14 PM
jhedges15's Avatar
Makes sense. I was goin to change the diff oil in it cuz some leaked out and it needs it done. Is there anything else I should do to make sure there isn't any mud or water in it?
Old Jun 8, 2009 | 03:16 PM
When you have the diff cover off, rinse the pumpkin out with some solvent, kerosene, or diesel fuel and let it dry thoroughly.
Old Jun 8, 2009 | 04:22 PM
kingfish51's Avatar
Also, if you decide to do your rear and you have a limited slip diff, make sure to add friction modifier to it, assuming the replacement fluid you use doesn't already have it.
Old Jun 8, 2009 | 05:27 PM
jhedges15's Avatar
What type of solvent do you mean?
I did the rear awhile back with royal purple fluid which had the friction modifier in it.
Old Jun 8, 2009 | 11:53 PM
Parts cleaning solvent.
Old Jun 11, 2009 | 04:55 PM
jhedges15's Avatar
need help...
went to fix this today. cut it expecting to find wires but didnt. just an empty plastic tube.
how should i go about fixing this?
Old Jun 11, 2009 | 07:06 PM
kingfish51's Avatar
Those are the vacuum tubes I talked about.
Old Jun 11, 2009 | 07:30 PM
jhedges15's Avatar
yeah i figured that but how do i fix it?
Old Jun 11, 2009 | 10:52 PM
fordmerc's Avatar
Looks like you are buying a new vacuum line setup. Also, when you change the front diff fluid, you don't have to remove the cover, there is a drain and a fill plug on the front of the diff. You will need some small diameter hose to pump the fluid into the diff from the oil bottle.
