Rough idle after spark plug changeout, 04' 5.4
Old Jun 3, 2009 | 09:25 AM
hellbnt4lther's Avatar
Changed plugs yesterday, 04' 5.4, 68K miles, not an easy task. Anyway, got plugs changed, re-connected everything back up, vacumn lines, main computer, etc. double-checked everything was like before, and it ran crappy at first, rough idle, died at a complete stop. Ran a little better after a test spin, runs fine on the road, just when coming to a stop or idiling, rpm's drop to 400-600, jumping, then finally dead?? Ran it again to work this morning, it does seem a little better, didn't die at each stop, just right when I got to work? Any info?? I did disconnect the battery to see if it needed to reset itself, and hooked a code reader on it, not throwing any codes, no check engine light either, any help oout there??
Old Jun 4, 2009 | 02:21 PM
Did you clean the cop springs and use dielectric grease in the boots?
Old Jun 4, 2009 | 02:43 PM
Yes I did. Now the truck only idles down to 400rpm's when I come to a complete stop, dies once in awhile but not everytime. Once I put it in park, idles fine???
Old Jun 4, 2009 | 03:05 PM
Matts ford's Avatar
what brand plugs? look for a vacuum leak. do you have a cold air intake? any kind of tuner? i'd take it to the dealer and see if there are any updates needed for your computer.
Old Jun 4, 2009 | 08:05 PM
ju015dd's Avatar
Do a good check for some sort of vacume leak. Make sue all connections are nice and secure.
