IAC question
Old May 15, 2009 | 05:21 PM
toast1850's Avatar
IAC question
Just a quick question. I have a 05 f150 with 4.6 trition. i want to clean the IAC. can i do this with brake cleaner? If not, please let me know what is safe. Thanks
Old May 15, 2009 | 05:34 PM
Matts ford's Avatar
you dont have an iac on yours. yours has a drive by wire system. everything is controlled with the throttle body.
Old May 15, 2009 | 11:05 PM
4play2008's Avatar
mine is a 2000 f150 5.4, and it's drive by wire and I have one.
Old May 15, 2009 | 11:24 PM
FordMasterTech's Avatar
The "drive by wire" phrase is used with the meaning of electronically controlled throttle actuation/idle through the electronic throttle body;
therefore, there is no need for an Idle Air Control valve.
The 2000 F-150 with any factory engine/trans configuration, is not "drive by wire" in the context referred to in the previous reply. It has an accelerator cable to manually open the throttle plate. The IAC's duty cycle will increase when the throttle position sensor "sees" a closed throttle, sustaining idle speed to the programmed threshold in the PCM.
FordMasterTech
Old May 27, 2009 | 11:10 AM
toast1850's Avatar
Rough idle
So here is my other question. I have been dealing with a rough idle ever since I bought the truck. I have replaced spark plugs, cleaned the maf sensor, cleaned the throttle body, replaced the pcv valve, and checked the air filter and it is clean. Can anyone give any more suggestions or ideas to why it still idles rough? Also, I have checked the rubber hoses near the back of the throttle body to see if they were cracked but they appear fine. The truck only has 36,000 miles. Any help would be greatly appreciated. Thanks
Old May 27, 2009 | 09:07 PM
Matts ford's Avatar
i didnt think your truck had a pcv valve? or is it only the 5.4 3v that doesnt? are there any codes? vacuum leak? is the truck 2 or 4 wheel drive? if 4 wheel drive, does it have the shift on the fly?
Old May 28, 2009 | 12:45 AM
Steve83's Avatar
Originally Posted by toast1850
I have been dealing with a rough idle... I have replaced spark plugs, cleaned the maf sensor, cleaned the throttle body, replaced the pcv valve, and checked the air filter and it is clean. Can anyone give any more suggestions or ideas to why it still idles rough?
Because you haven't diagnosed or repaired the fault. Blindly throwing part$ at it is the slowest & most expensive way to fix anything. If you can't diagnose it, pay a pro - it'll be cheaper in the long run.
But in this case, you don't even have to do that. Keep reading...
http://www.epa.gov/otaq/consumer/warr95fs.txt
Old May 28, 2009 | 12:56 AM
jrfonte's Avatar
my truck has a rough idle to it has been there since it had 18k mi on it took it to the 4 dealers in my area and they all said the same thing. there is nothing wrong with this truck.
Old May 28, 2009 | 01:02 AM
hillbilly4u's Avatar
Read this thread it could be your problem.
https://www.f150online.com/forums/20...fuel+injectors
Old May 28, 2009 | 09:58 AM
toast1850's Avatar
The truck is 2wd stx model. it does not have check engine light on. i took it to ford and they hooked it up on their scanner and they said nothing was wrong with it. they said it was supposed to idle this way. i could possibly have a vacuum leak but wouldnt know how to check that. i don't have the 5.4 3v, i have the 4.6, so would the injectors still apply?
Old May 28, 2009 | 08:08 PM
Steve83's Avatar
If they gave you a completed repair order that says it's OK, you're covered. If anything happens later on, you can submit that document as proof that it's Ford's responsibility. If you do anything else to it, and something goes wrong, it's your fault & they won't cover it.
Old May 29, 2009 | 01:55 PM
Matts ford's Avatar
the injector issue was only with the 05 5.4 3v engine. its still a posibility but i dought yours would be an injector issue. how rough is the idle? what rpm does it idle at/around?
Old Jun 1, 2009 | 11:29 AM
toast1850's Avatar
my truck does not have an rpm gauge, but when it idles its bad enough to see the passenger seat shake.
Old Jun 1, 2009 | 02:24 PM
Matts ford's Avatar
ok so the only problem is a rough idle? no misfire under acceleration or anything? any cel? unplug each coil one by one with the engine idling and see if the engine runs different or not. if it doesnt run differently after unplugging a coil then shut engine off and pull the coil and plug for that cylinder. does it have any aftermarket parts on it?(K&N filter? throttle body? intake? etc) does it have a tuner in it?
Old Jun 2, 2009 | 09:21 AM
toast1850's Avatar
yes only problem is a rough idle, no cel, no misfire under acceleration, etc. i just changed out the spark plugs yesterday, i put in motorcraft platinum, seems to be running betting but still has rough idle. the engine is completely stock. no tuner
