new heads for an 01 F150 4.6L
Old Mar 29, 2009 | 05:23 PM
cheesecake07's Avatar
my truck blew a spark plug twice on cyl num. 2 and instead of getting it rethreaded I was gonna get new heads but I wanted to upgrade not just replace and was wondering if anyone knows if the new 3V or mach 1 DOHC fit my truck engine
Old Mar 29, 2009 | 05:29 PM
built54's Avatar
sure they fit, but you need the timing cover and intake manifold to go along with it, and different exhaust manifolds and tuning
Old Mar 29, 2009 | 05:47 PM
besides manifolds and timing covers what else would I have to replace??
Old Mar 29, 2009 | 05:50 PM
Matts ford's Avatar
the front of the exhaust system. tune. i'm sure there will be more wiring to do. air induction. and i'm sure theres much more.
Old Mar 29, 2009 | 05:57 PM
so you guys recomend just sticking to the 2V?? instead because this was my daily driver and need it back asap
Old Mar 29, 2009 | 06:35 PM
Matts ford's Avatar
if thats the case then you could just get a 97-03(and 04 heritage) 5.4 2v and there wont be any other mods needed. you'll just need a tune. you can swap the engine and get a tune and you'll be on your way.
99-03 5.4's had the pi(performance improved) heads. 97-98 didnt. there was about 15hp difference.
4.6 Punisher's Avatar
Would he have to replace the intake manifold as well?
Old Mar 29, 2009 | 06:36 PM
Matts ford's Avatar
yup
Old Mar 29, 2009 | 06:54 PM
Have you tried a Timesert yet? We have a member (Galaxy) that rents out a kit. There's also www.blownoutsparkplug.com. These procedures do not require head removal.
Old Mar 30, 2009 | 06:39 PM
I havent but I thought you couldnt rethread aluminum heads??
Old Mar 31, 2009 | 02:48 PM
Why not? All you are doing is reaming it out oversize, then threading it for an insert. The inserts, if properly designed and installed, essentially become a permanent part of the head. The Timeserts work better than any other "do it yourself" inserts (i.e. helicoil), and the guys at blownoutsparkplug.com have designed special inserts that work better than anything.
Old Apr 2, 2009 | 09:11 PM
okay then thanks
Old Apr 2, 2009 | 10:20 PM
jbrew's Avatar
The boys over @ Timesert.com already have you covered. It's called the BigSert lol - Not kidding.
It's #2 ??? From what I've seen - You'll have it fixed in 15 minutes and never have another problem with it.
I wouldn't do 3 valve heads if they were given to me anyway lol. Not on that truck. I would find a good set of 2 valve heads and send them out.
BIG-SERT® OVERSIZED SPARK PLUG THREAD REPAIR KIT
http://www.timesert.com/html/bigsert_sparkplug.html
