NEED HELP, engine died while driveing
Old Mar 7, 2009 | 01:31 PM
nate83's Avatar
ok, so i was pulling out of the parking lot, and the engine just shut off, no warning or anything, truck seemed just fine from my house to the store and when ii started it when leaving,I tried to start it again but no power going to starter, engine light and little wrench light on, im using a maxenergy programmer so i hooked it up and there are no dtc's showing up, also can't return programming to stock gives me 1800 # to call. .....truck still has power but when turn guy nothing happens, any insight would be great...just when i told the guys at work that i haven't had a single problem with my ford, lol
Old Mar 7, 2009 | 01:46 PM
jethat's Avatar
Please fill out your member profile information so your truck model year and engine type come up one every post like mine does. With out that information we can only guess..
Old Mar 7, 2009 | 02:34 PM
nate83's Avatar
sorry, 2004 5.4 3v
Old Mar 7, 2009 | 03:27 PM
Matts ford's Avatar
tap the starter with something hard and see if it'll turn over, dont go crazy with whatever you use. does the solenoid even click? you better talk to those guys at work and find out if they touched your truck
Old Mar 7, 2009 | 03:40 PM
jethat's Avatar
I would disconnect the positive side of the battery and the negative, clean the terminals and replace them. If that didnt fix it I would short the big post to the small post on the relay. If it starts you need a new relay, If it doesn't start then I would check the connections on the starter solenoid on the starter. Look for corrosion on the main wire.
Old Mar 7, 2009 | 04:34 PM
nate83's Avatar
i was thinking it could be the starter but why would the engine shut off while i was driving?
Old Mar 7, 2009 | 04:41 PM
Matts ford's Avatar
it could be the battery is low and wont take a charge or the alternator isnt putting anything out. i know on a bunch of diesel trucks and tractors once the battery got down to a certain voltage i think 7 volts the engine would shut off i'm not totally sure about these trucks though. and once its too low it wont be able to start either.
Old Mar 7, 2009 | 05:20 PM
jethat's Avatar
its not the starter. They rarely fail. check the basic connections first.
Old Mar 7, 2009 | 06:32 PM
hntr4life's Avatar
along the same lines with my 05. will turn over but not start. tried a new fuel pump module, but no change
Old Mar 7, 2009 | 06:36 PM
Matts ford's Avatar
his wont even crank. check your fuel pressure and the injectors if you have a 5.4.
Old Mar 8, 2009 | 01:33 PM
JMC's Avatar
JMC
25 Year Member
Start by returning the truck to stock. Hint; if the tuner tells you to call an 800 number for assistance, do it. Once you have the corrupted program removed from the PCM try starting it again.
Old Mar 8, 2009 | 03:45 PM
nate83's Avatar
had truck towed to dealership, can't call hypertech till monday morning, i don't think it's the programmer, been using it for last 70 000 km with no trouble, but i'm assuming dealership can't run diagnostics untill aftermarket programming is removed, checked battery connections,battery less than yearold (six pack deep cycle) also checked voltage and its good...hopefully they can figure it out....good time to some overdo maintainence anyways
Old Mar 8, 2009 | 03:51 PM
Matts ford's Avatar
something may have locked up on you. like the alternator, a/c compressor, p/s pump. you'd have to pull the belt off turn the crank and all the pullies. what brand battery do you have?
Old Mar 8, 2009 | 04:08 PM
nate83's Avatar
i thinks it's an orbital extreme duty, but the battery seems fine
Old Mar 8, 2009 | 04:34 PM
ShadowSTX's Avatar
I've had the same thing happen to me......
IMO, from what you said your truck did, I would suggest that it's the battery.
One morning, when I was leaving the house, my truck started up fine....went back into the house because I forgot something, came back out and when I was taking off the truck just died. No warning or anything. I thought it may be the battery, due the truck not turning over when starting so I jumped it with another truck....it started up and I took off for work.
Or so, I tried to....
When I was going down the road, the truck died again and I had no choice but to let it coast as far as I could get. Parked it. Came back later with a new battery, hooked it up, truck started right up and everything was fine. Auto parts guy told me that some new vehicles have a safety(?) feature that actually shuts the motor off if the battery charge is too low.
