Coolant leak
Old Feb 14, 2009 | 01:40 PM
JMC's Avatar
JMC
25 Year Member
Truck is fixed. Did not remove manifold. Went to parts store and purchased a miracle in a can cracked cylinder head sealer. No more leak. But that did not totally fix it. It did however seal the leak in the rad. Turns out that the hose had an other slit. I cut more off the hose and will replace it later today or tomorrow. Has anyone ever seen a heater hose get hard. By that I mean no longer remain flexible. Mine seems to get brittle where it attaches to the metal tube. Then it cracks and leaks. To quote Artie Johnson; "Verry interresting"
Regards
Jean Marc Chartier
Old Feb 14, 2009 | 01:55 PM
ONELOWF's Avatar
Originally Posted by jbrew
are you sure it's leaking at the manifold fitting ?
Good one jbrew.
Old Feb 14, 2009 | 02:21 PM
JMC's Avatar
JMC
25 Year Member
I guess we will never know if the fitting ever leaked. If you look closely at the picture you will notice that the tube is dry except where there is a pool of coolant at the base. That picture was taken after the hose was repaired and I ran my fingers around the tube to check for moisture and there was none. Except for at the base. Today I had to cut 2 inches from where the hose attaches to the tube to get all of the new slit. I suspect that if I leave on it any longer it will start to leak at other points along the hose. Touch wood, at least it isn't the heater core.
Old Feb 15, 2009 | 03:54 AM
Klitch's Avatar
JMC, ive seen lots of brittle non flexible hoses, you ever seen a 93 ford probe? lol
