Got a quote for a tune-up.
Old Jan 20, 2009 | 03:21 PM
shroville's Avatar
Called are family mechanic and got quoted for plug change a cop install
got quoted 300 is that fare?
also i mentioned i wanted motorcraft back in there and he said he could probably put something better in there besides motorcraft what would that be?
i already have the cops but have not bought the plugs yet
sorry if im kicking a dead horse but ya know how it goes.....
2002 5.4 fx4
thanks!
Old Jan 20, 2009 | 03:36 PM
polevaulter95's Avatar
well from what i read only run the motorcraft plugs in there. i mean hey you know it works why put something "better" in there. and for the $300, it all depends on how much your own time if worth.
i helped a friend change his plugs and instal new cop's and let me say it is pretty involved, but still straight forward. We were able to do it in an afternoon with a few swear words along the way.
there is a good write up on here somewhere that i used. good luck
Old Jan 20, 2009 | 03:45 PM
shroville's Avatar
oh and also he wanted to use antiseize if i remember correctly that was a big nono am i correct?
Old Jan 20, 2009 | 05:23 PM
Triple900's Avatar
Just got the plugs in my 05 5.4 changed at a ford dealer two hours ago $268 with new motcraft plugs
Old Jan 20, 2009 | 05:38 PM
jethat's Avatar
The dealer charged me $200 to install my parts plugs coils.
Old Jan 20, 2009 | 05:42 PM
You do not use anti sieze on a 2002. They have problems keeping the plugs in. go with Motorcraft plugs. I would look for someone that knows more about Fords.
Old Jan 21, 2009 | 03:26 AM
You also should torque them to 28 ft/lb instead of the recommended 15.
Old Jan 21, 2009 | 10:45 AM
SkyBound85's Avatar
Is there any risk of damaging the heads/threads by doing this? I need my plugs changed soon and if I tell the dealer to torque them to 28ft/lbs will they actually do it?
Old Jan 21, 2009 | 10:56 AM
97fordnut's Avatar
I was told that the 04-08 3 valve torque was 25-28 ft/lbs and the 97-03 2 valve was 14-16 ft/lbs. Use antiseize on 3 valve and no antiseize on the 2 valve. There is only like 5 threads in the 2 valve head and if they are over torqued it will damage the threads causing a plug launch same will occur if they are under torqued or if antiseize is used. I did mine about a year and a half ago and didn't have any problems torqued at 16 ft/lbs.
Old Jan 21, 2009 | 12:57 PM
wookie13's Avatar
if the 2v has aluminum heads why is anti-sieze NOT reccomended? Just curious as I have to change my plugs soon on my 2002 5.4 4x4 screw.
Old Jan 21, 2009 | 01:14 PM
Because they do not have enough threads to hold the plugs in. The plugs have a tendancy to back out slightly, then blow ot, stripping the threads. Do a search on the plug blow ot problem. Anti-sieze would just make it easier for them to back out.
Old Jan 21, 2009 | 01:52 PM
shroville's Avatar
I have this local guy that does work out of his house i went over there a couple weeks ago just to talk and i saw he had another f150 sitting there i asked him about it, he said he just did a tuneup on it..
i wonder if he will let me sit in on the exchange... and give me a better price also! that would be sweet....
but then again what about that torque spec.... 16 or 28?
Old Jan 21, 2009 | 03:13 PM
SkyBound85's Avatar
does torquing the plugs to 28 ft/lbs also apply to the 4.6? I'm a 2003 4.6L
Old Jan 22, 2009 | 02:23 AM
http://www.blownoutsparkplug.com/faqs.htm FAQ #48
This applies to all 4 thread heads. I don't know about the 8 thread heads, and it definitely doesn't apply to the 3V heads.
Old Jan 22, 2009 | 03:59 AM
Fifty150's Avatar
Your dealership should perform all service work to specs set forth in the Ford service manuals & supplemented by TSBs. Then they should be able to warranty the work that they perform. Here in CA, they are suppose to warranty their parts & labor for 1 year. If nothing goes wrong in a year, then you've gotten your money's worth.
