2000 f-150 plugs
Old Jan 6, 2009 | 12:10 AM
jjbigg's Avatar
2000 f-150 plugs
Does this model year have problems with broken plugs...and replace with what brand
Old Jan 6, 2009 | 12:42 AM
jethat's Avatar
broken plug problem is on the 04-07 3v engines. Motorcraft plugs are best.
Old Jan 12, 2009 | 08:44 PM
flbuilder1's Avatar
jjbigg, Did you replace yours and how did it go. My 2000 is ready for replacement and I usually pay to have it done. After reading all the different posts I'm going to change them myself. Broke a plug off in a 92 Dakota V6. What a pain. Don't want to go through that again.
Old Jan 13, 2009 | 03:48 AM
The 2000's are the ones that have a tendency to eject plugs. Do not use anti-seize on them, and torque them down tighter than the factory 15 ft/lb specs - go for about 28.
Old Jan 14, 2009 | 03:42 PM
flbuilder1's Avatar
glc, Are you saying it actually pushes the plug out of the block?
Old Jan 14, 2009 | 03:45 PM
Not just push, spits or blows. Usually destroys a COP at the same time.
Old Jan 14, 2009 | 03:52 PM
shroville's Avatar
thats the first time ive heard the torque them down higher then 15.
to be safe should we really be torgueing them at 28? will that help a blowout
Old Jan 14, 2009 | 04:01 PM
flbuilder1's Avatar
I have 250,000 and haven't had that problem knock on wood
Old Jan 14, 2009 | 04:04 PM
4wd150's Avatar
is that 250,000 miles on original motor? how long ago u change plugs. but damn im hopin mine goes up there in mileage. good job!
Old Jan 14, 2009 | 04:18 PM
The problem is that the heads for a few years had too few threads in the sparkplug hole. The plugs would work loose and then when only 1 or 2 threads holding, the plug will blow, stripping the threads out. Requires a Timecert or Helio coil to repair, or new head. Do searches using key words, you will find lots to read.
Old Jan 14, 2009 | 04:22 PM
flbuilder1's Avatar
same motor. I haven't really had many problems with the truck as a whole. I've replaced both upper control arms,both remote door acuators,spare tire holder.I have a problem now with a coolant leak that I posted.My mechanic says the engine is bulletproof and I can't complain.As far as the plugs,I have always taken it to mechanic when it starts running rough( as it is right now) and let him change them and the coils. I have only had done it twice since I've had it. I'm going to try it myself this time.
Old Jan 14, 2009 | 04:23 PM
Gotts2BMe's Avatar
A few years? try 91-03 lol
Old Jan 14, 2009 | 04:33 PM
I was trying to remember the years, so a BIG few. Actually, I thought they got it fixed along about 2002 or so. I never had the problem so was trying to recall what I had read.
Old Jan 14, 2009 | 04:40 PM
Gotts2BMe's Avatar
the heads started production on March 12 2002 but never actually hit the production till after April 2003 at the latest. I was looking for a motor with the updated heads and the newest salvage I could find still had the 4 threaded plugs which was assembled on April 1 2003.
Old Jan 14, 2009 | 04:41 PM
Thanks for adding the correct info.
