Coolant Refill 2008
Old Dec 14, 2008 | 11:46 PM
corvet3640's Avatar
Whoa. No need to get hot over coolant!
Old Dec 15, 2008 | 12:05 AM
Ilovemyford's Avatar
Originally Posted by Sixeye
... Okay, I see that on the Prestone label now. No wonder there is no mention of it in the owner's manual. ....
I hope you are not mixing Prestone with Motorcraft Premium Gold coolant. It's a big no no. Mixing coolants may degrade coolant’s corrosion protection.
Old Dec 15, 2008 | 12:09 AM
Originally Posted by Galaxy
Sorry bro, but that's incorrect. You always referr to everything from the drivers point of view. Go look up an exhaust manifold or valve cover or any other part for the "drivers" side and see if it's labeled right or left. Come back and let us know what you find out too!!
sixeye... Don't buy power steering fluid for your reservoir. It calls for ATF. Don't remember which type, but it is regular ATF, not PS fluid.
Mercon V is what is used for the power steering in our trucks.
Old Dec 15, 2008 | 12:16 AM
corvet3640's Avatar
yup atf
"Power steering fluid
Fill to between MIN
and MAX lines on
reservoir
Motorcraft
MERCON V"
from the 08 manual
Old Dec 15, 2008 | 03:54 AM
code58's Avatar
Originally Posted by Soaring
The radiator reservoir tank is way over to the right. There seems to be some yellow **** in it. Is that the color of anti-freeze for that year model? And, we describe an engine compartment from standing in front of the vehicle. So, the driver's side is the right side. It's not rocket science.
That is most likely your power steering fluid tank. Trace it to the source.
You may, but the rest of the automotive world doesn't. R & L is ALWAYS determined from the drivers seat. If you were ordering parts you'd find out in a hurry when you were ordering parts for the wrong side of the vehicle and chewing THEM out for giving you the wrong ones!
Old Dec 15, 2008 | 04:02 AM
code58's Avatar
Gee, I'm a bit red faced. I was preparing to replace the coolant for the first time in my 2008 F150. No radiator cap! Egads! When did they do away with that? Do I refill by pouring the new coolant and water in the overflow reservoir?
Sixeye- All your doing is throwing good long life coolant away if you're changing that gold coolant every year. It's not called long life for nothing. I still have it in my '04 f-150 and will for a while- and I am METICULOUS about how I maintain my vehicles. Don't remember just how many miles or years it's good for but a loooong time. And don't make the mistake of putting regular coolant back in it. All vehicles that I know of now use long life coolant and some us EXTRA long life coolant.
Old Dec 15, 2008 | 04:11 AM
code58's Avatar
Good grief. What a bunch of horse crap. The proper way to add fluid to the system is to add it to the overflow/expansion tank. Read your ****in" manual.
If your wise you'll listen to Quintin- he has more answers than you do questions- and they're generally the right ones too. If you're not, well then, you'll do what you want to- but that won't make you right.
Old Dec 15, 2008 | 11:34 AM
jbrew's Avatar
Originally Posted by Quintin
F'k off and die, douchebag, I do this for a living.
ETA - Yes, adding coolant to top it off, add it directly to the tank, no problems. However, when the cooling system is empty, refilling it directly through the expansion tank will create an air pocket.
Disconnecting the heater hose while filling through the expansion tank gives the air someplace to escape.
This is what I haven't done in the past. I still get that gurgling after shut down that drives me nuts.
So the heater hose is the trick ? Good post Quintin .
When I refill , I usually just leave the top hose disconnected from the pump. When coolant makes it's way thru the pump, the block is bled. After that, I just follow the Ford bleeding procedure, but it doesn't work. There's still air in there somewhere, I can hear it after shut down.
I also have that coolant tree on the throttle body. I'll give that heater disconnect a try this time.
Old Dec 15, 2008 | 06:20 PM
The long life coolant is good for 5 years or 100k if I'm not mistaken.
