Spark Plug suggestions...
Old Dec 11, 2008 | 02:59 AM
GSXRZ28's Avatar
Ok well I'm about to replace the plugs on my truck. It has a small misfire at idle and its slowly gotten worse. Any suggestions on what to do and what not to do? Any help would be appreciated...
Old Dec 11, 2008 | 10:14 AM
cdn2usa's Avatar
Do you have the 5.4 and was your truck built between 2004 and 07? If so do a search, there is a lot about this subject and broken plugs.
Old Dec 11, 2008 | 10:25 AM
BLUE20004X4's Avatar
I think the only thing is with yours assuming it's an 04 like your stats say is once they ALL come out, the new ones get a light coating of anti-seize and torqued.
Old Dec 11, 2008 | 10:28 AM
Yep, go back with the Motorcraft with a coating of nickle anti-sieze on just the long shank, not on the threads. Be sure and do some research on the TSB so you know what to expect and how to go about the removal.
Old Dec 11, 2008 | 10:37 PM
GSXRZ28's Avatar
Ya its an 04 with the 5.4l.......
Old Dec 12, 2008 | 12:05 PM
Before you try to pull those plugs, you need to spend some time reading threads here about the sticking and breaking issues. Ford has a TSB that has very specific instructions on how to do it, and if you do break any, you will need special tools to recover. I think the 04's were the worst because they didn't use antisieze at the factory.
Old Dec 12, 2008 | 12:28 PM
Quintin's Avatar
If it's got over 50K miles on it, IMO it's safe to assume that you're gonna break some plugs upon removal.
Old Dec 12, 2008 | 01:44 PM
metcalfe's Avatar
after breaking 1 and having the lisle extractor not work and several, several hundreds of dollars later...my advice is to take it into a good dealership. I know it's hard to find sometimes, but I brought mine into 1 to finish a job that I, and a machine shop, couldn't finish. Ford got it done in half a day.
if you do try it yourself, the ford technician told me his trick was to epoxy a piece of wire to the broken porcelain, and pull it out after it sets up. Then an extractor will work. He was actually a pretty cool guy. I guess he felt bad for all the trouble I got myself in. he said they do them all the time, but still cringe every time they get one.
Old Dec 12, 2008 | 11:19 PM
GSXRZ28's Avatar
Damn what to do now. I'm scared but I wanna try it....lol! Truck has 80k miles on it.
Old Dec 12, 2008 | 11:50 PM
MikeSwt's Avatar
DO it DO it!
Old Dec 14, 2008 | 11:23 AM
mjt123's Avatar
What plugs would you guys suggestion going with for a F150 2006 5.4
Thx Mike
Old Dec 14, 2008 | 11:57 AM
jessiebouc's Avatar
I had my plugs changed by the dealer, most posts say to stick with motorcraft plugs.
Old Dec 14, 2008 | 11:58 AM
You don't have much choice, there aren't too many available. The current recommendation is Motorcraft PZT14F.
Old Dec 15, 2008 | 12:54 AM
GSXRZ28's Avatar
Whats wrong with the other plugs that are available?
Old Dec 15, 2008 | 06:31 PM
They are not manufactured to Ford specs.
