5.4 tick
Old Dec 3, 2008 | 06:54 AM
map22's Avatar
5.4 tick
any suggestions on how to maybe solve this problem? its not too bad, i just would like to try and fix most of it. thanks..
Old Dec 3, 2008 | 09:37 AM
SMIGGS's Avatar
Try looking at the exhaust manifold bolts on the passenger side. I have a 2 5.4's and both have the same bolts broken.
Both make a "ticking" sound. I'm getting one fixed next week so hopefully that's the ticket.....
Old Dec 3, 2008 | 01:34 PM
Camarothatcould's Avatar
Um, more information maybe???
KNOWN ticks for mod motors. . hmm, lets see
INJECTORS-normal
HLA(Hydraulic Lash Adjuster)
EXHAUST MANIFOLDs( either cracked or broken studs)
HEAD GASKET(leaks compression)- MY VERY OWN MONSTER
More symptoms or video clips
Old Dec 3, 2008 | 01:37 PM
azmidget91's Avatar
also could be your spark plugs coming loose
Old Dec 3, 2008 | 01:40 PM
oh noez!
Old Dec 3, 2008 | 05:40 PM
97F150 5.4's Avatar
Hmmm Maybe thats my Problem I have a VERY small Tick.... hardly Noticeable and maybe thats what throwing my Check engine and the drivers side bank... hmmm
Old Dec 8, 2008 | 02:39 PM
SoundQ's Avatar
I had the same problem with my 06 Roush Stage 1 5.4, It turned out to be a factory defect in the heads, Roush only gives you a 3 year or 36,000 miles warranty on the truck which they changed in the 07's. I just bought a new motor and getting it installed as we speak! I will teardown the original and inspect it! Will keep you all post on the findings! But the symptons was ticking in the motor, then tripping CEL with codes#P0344 and P0340 in the Bank 1 and misfiring! Then this month I lost all power and stalling on the hwy with hard to start! The Truck has 84,000 miles of hwy traveling and local driving on the motor! I have tried new coils and plugs, VCT solenoids on both banks and new cam sensor to no avail. Ford recommended a new motor!
