WHat's a good Portable Battery Booster?
Old 11-24-2008, 12:56 AM
harly4d's Avatar
Originally Posted by JMoreland
Yeah, never heard of anything good from there. I got this one as a gift, just wish it would have lasted longer.
Bring it back. Most stores are VERY good about replacing faulty equipment. Just tell them it was a gift and that you can't find the receipt!
Old 11-24-2008, 12:58 AM
JMoreland's Avatar
Think they'll still do it considering it is almost a year old?
Old 11-24-2008, 01:00 AM
Blown F-150's Avatar
Originally Posted by Fifty150
I'm thinking about putting a couple on top of my cab, and then daisy chaining a few more over the tonneau cover.
Sunforce 50032 15 Watt Solar Battery Charger
Item#: 50032
UPC#: 834319000655
* Works with Automobiles, RV’s, Boats,Tractors, ATVs, Electric Fences, Deer Feeders, Telemetry, and More
* Maintenance Free / Easy Installation
* Works in All Weather Conditions
* Ultra Bright Blue LED Provides Charging Indication
* Built-in Blocking Diode Protects Battery Discharge at Night
* Made of Durable ABS Plastic with an Amorphous Solar Cell
* Temperature Range: -40° to 176° F
* Max Output 15 Watts 1 Amp
I don't know what's down there as an equvilent, but at Canadian tire they have a nice one that goes sits on your dash and plugs into your cigarette lighter, I believe it's 7.5 watts. I've been holding out, but I don't want to wreck a battery I just put in it 8 months ago.
Old 11-24-2008, 01:24 AM
harly4d's Avatar
Worth a shot. I know my local store would - and wouldn't even bat an eye. They'd just tell you to go get a new one and have a nice day. They know there stuff is cheap
Old 11-24-2008, 02:21 AM
code58's Avatar
I shop at HF all the time and they are one of the best stores for exchanging stuff that I've dealt with. No questions asked.
Old 11-24-2008, 02:39 AM
code58's Avatar
Originally Posted by Blown F-150
I'm thinking I am needing one now too. I have been in LA for the last two weeks on a project and just went to start the truck to take it out for a spin. It went Crank, Crank, Click.
I was thinking about one of those solar panels that go on the dash and plug into the cigarette lighter. anyone have any experience with one?
I use one of those (and yes it is from Harbor Freight) and it works great. I don't use my truck a lot since gas went through the roof (back down now), but i don't have to even think about it. Just plug it in and forget it. They put out enough juice to keep a battery up as long as you don't have shorts or excessive parasitic drains. They keep my battery up fine even if I don't use it for a few weeks (I know because I load test my battery at least every month or two). Also, you don't have to worry about a solar charger messing your battery up (unless it's a solar that's too big to fit on your dash) They should put out just enough to maintain, not charge up. They also will charge on a cloudy day- doesn't have to be sunny. You can tell by how fast the LED light is blinking the rate at which it is charging. It will charge with any light source, even a light bulb.
Old 11-24-2008, 01:53 PM
Matts ford's Avatar
thats what alot of dealers use. it works great for what there used for. all they do is maintain the charge on a sunny day.
Old 11-24-2008, 05:03 PM
That sounds good. I'm not expecting it to work miracles or anything, bhut it would be great to help off-set the draw on the battery while it sits. I will be installing switches to shut-off all power to my LCD screens and Sattlelite radio. Not sure what to do about the door solenoids, maybe a hidden shut-off switch. something pretty heavy duty. Sorry for the thread jacking and thanks for the help!
Quick Reply: WHat's a good Portable Battery Booster?
