installing powermaster alt
Old Nov 6, 2008 | 10:17 PM
king ranch's Avatar
I have a powermaster 200amp alternator and i am looking to install on my truck, just wondering exactly how do i install it wires and such wat i need to hook up and what i dont need to hook up
heres the link to the alternator i have
http://www.car-stuff.com/carparts/fo...p66477641.html
Old Nov 6, 2008 | 10:31 PM
Richard D's Avatar
Should be a direct bolt in, just hook the wires up just like they are on the current alternator
Old Nov 6, 2008 | 10:46 PM
king ranch's Avatar
thats how the back looks, and also how do i loosen the belt to get the stock alternator off
Old Nov 6, 2008 | 10:51 PM
Richard D's Avatar
1/2" drive breaker bar to release the tension on the Belt Tensioner
Old Nov 6, 2008 | 11:03 PM
king ranch's Avatar
ok where can i get that from, and the big black piece with a screw you connect that with a 1/0 run of wire to the pos battery terminal and the rest just connects or what
and where is the belt release thing at
Old Nov 6, 2008 | 11:41 PM
Blown F-150's Avatar
there are three bolts that hold the Alternator on the motor, they are all 10mm. The Belt tentioner is to the lower left of the alternator if your looking from the front of the truck. You'll see a 1/2 square hole to insert a breaker bar into, the longer the better. Once you have the breaker bar in, you will push the bar to the right turning the tensioner clockwise, slide the belt off of the alternator. Then unbolt the three 10mm bolts holding the alternator in place, lift the alternator up a little and unbolt the ground wire from the post on top of the alt. then using a small flat screwdriver CAREFULLY lift the locking tabs and unplug the two connectors. Do the reverse to re-install you new alternator.
Hope this helps! Good luck.
Old Nov 6, 2008 | 11:47 PM
king ranch's Avatar
helps alot thanks so with that black piece with the bolt on it is that my power or ground connection
Old Nov 7, 2008 | 12:16 AM
Richard D's Avatar
Positive/Power
Install everything just like the factory parts are.
Old Nov 7, 2008 | 12:23 AM
king ranch's Avatar
where can i get a breaker bar,and the black piece with the bolt wat connects to that pos or ground
Old Nov 7, 2008 | 01:09 AM
It's a positive line, Once you have a look at your alternator on the truck, it will all make sense. You should disconnect your battery while your doing this too.
Go to your local sears or any autoparts place, it's a 1/2" breaker bar, also known as a "johnny" bar. I've done it with a 1/2 ratchet, but it's not fun.
Old Nov 7, 2008 | 01:26 AM
king ranch's Avatar
yea i will prob try with the ratchet and see how that goes, should i use a inline fuse for the postive line from the alt to the battery, so there is no ground i have to hook up
Old Nov 7, 2008 | 06:47 PM
JTE3097's Avatar
If you use a ratchet, you'll want a 2-3 ft cheater bar. It's pretty springy.
Old Nov 8, 2008 | 12:43 AM
king ranch's Avatar
ok how do i get the pulley off the stock alternator is a certain tool needed
Old Nov 8, 2008 | 12:17 PM
Richard D's Avatar
Why are you trying to take the pulley off?
You will need a impact gun to remove a pulley
Old Nov 8, 2008 | 12:47 PM
jbrew's Avatar
It didin't come with a pully ?
It should have -
"POWERMASTER ALTERNATOR, NATURAL FINISH -- 200 Amps Output, Internally Regulated, Designed For An OE Look, Delivers High Output To Weight Ratios, Offers Low Drag And High Speed Bearings, With Proof Of Performance Tag, Includes Serpentine Pulley, Bracket Not Included"
