engine running bad
Old Nov 2, 2008 | 12:59 AM
king ranch's Avatar
engine running bad
long story short some dumbass took a hose to fill my windshield wiper fluid and he walked away and came back and the hose popped out and water went all over the engine and the engine was cold and he told me it happend on accident but i am pissed, and soon as he told me which was like 5 mins later i cranked it up for about 10 mins and let it run to burn try to get rid of any water on the engine, well today went to drive it and it runs like crap and my edge says p0300 missfire and p0308 cylinder 8 missfire was running great until this happend
today i drove it over 100 miles and kept putting it to the floor to try to make it stop running so bad but its not solving nothing
so what can i do to try to fix the problem
thanks
Old Nov 2, 2008 | 01:12 AM
king ranch's Avatar
help
Old Nov 2, 2008 | 01:34 AM
01 gt f150's Avatar
check DTC's. most likely a shorted coil, water in sparkplug hole between boot and plug. coil will most likely need to be replaced.been there done that.
Old Nov 2, 2008 | 01:36 AM
king ranch's Avatar
dtcs are one says unknown, other says random missfire detected, and the last says sylinder 8 missfire detected
so there is no way it will eventually run right and burn the water out of the engine or what
01 gt f150's Avatar
all modular coil packs 1998-2003 are the same. 4.6 and 5.4
Old Nov 2, 2008 | 01:38 AM
01 gt f150's Avatar
mine was shorted and burned. most likey is your case. luckily my neighbor is a head mechanic for ford
king ranch's Avatar
i have coil on plugs, so the engine wont burn the water out and run normal or will i have to replace the cop and spark plug
it says cylinder 8 so if i replace that one it also says random missfire how do i fix that, and the unknown dtc as well
Old Nov 2, 2008 | 01:40 AM
01 gt f150's Avatar
feels like a rod knock damn near. at least it"s and easy fix
Old Nov 2, 2008 | 01:41 AM
01 gt f150's Avatar
replace #8 coil pack and clear dtc's before starting again
Old Nov 2, 2008 | 01:43 AM
king ranch's Avatar
yea it runs bad like really bad once it kicks into od at about 42 or so it shakes the whole truck, so there is no way it will fix itself and burn the water out of the plug or cop
01 gt f150's Avatar
don't forget to check for water. more than likely evaporated already and left the bad coil to **** you off
Old Nov 2, 2008 | 01:46 AM
01 gt f150's Avatar
nope. the plug sit's down there pretty far and the coil boot let the water in. I had the exact same thing happen to me. also check to make sure you did'nt blow the plug threads. common problem. btdt
Old Nov 2, 2008 | 01:48 AM
king ranch's Avatar
okk
how much does a auto parts store charge for the coil on plug and do i need that or just the spark plug boot, or the whole coil
and wat do u mean check for water
Old Nov 2, 2008 | 01:03 AM
king ranch's Avatar
dammmmmm this shttt ticks me off man i cant believe this happend and i didnt know a lil bit of water would cause thhis much trouble either, how do people drive trucks through water and ponds and when the water goes over the hood
Old Nov 2, 2008 | 01:14 AM
01 gt f150's Avatar
the cop comes complete bolt in and it can't hurt to replace the plug for a couple of bucks
