Yellow clear fluid all over bottom of engine HELP! *PICS*
Old Nov 1, 2008 | 01:15 PM
littletunny's Avatar
99' Expedition 4.6
I noticed some oil on my garage floor when I had to move my truck. Drops weren't just in one location, they were everywhere so I poked my head underneath to look at the motor because I do have the notorius right head gasket "seep". Fluid is everywhere! In particular under the radiator near the front bumper.
I dont believe it is an engine oil leak because the oil on the dipstick is brown and this fluid is clean and clear and yellow, almost like hydraulic oil. My Radiator fluid looks green and the reservoir looks full. Is it brake fluid or transmission fluid??
It look like something actually sprayed it not just a leak. A powerful explosion maybe?? I know leaks get blown around but this was crazy.
I cranked it up this morning before I noticed the leak and it knocked a little then cleared itself up. It usually knocks anyway when its cold.
Thoughts???
Old Nov 1, 2008 | 01:21 PM
Matts ford's Avatar
whats the coolant and brake fluid level?
Old Nov 1, 2008 | 01:29 PM
beckerjs's Avatar
looks like coolant, pressure test the system, it will show. Smell it, somewhat sweet then its definatly coolant
Old Nov 1, 2008 | 01:36 PM
Camarothatcould's Avatar
ditch the Fram. . .
Old Nov 1, 2008 | 01:42 PM
Matts ford's Avatar
Originally Posted by Camarothatcould
ditch the Fram. . .
x2! thats your dry start issue
Old Nov 1, 2008 | 03:58 PM
Brake fluid = good = greyish
Power Steering fluid = good = red
Coolant = greenish yellow = barely below cold weather mark
However the coolant has more of a watery consistency.
The leaked fluid is much more viscous, kinda like gearcase oil. Is there a gearcase in the front?
It amazes me how the fluid is spread.
Should I wipe everything down and then start the motor to see if I can see anything??
Old Nov 1, 2008 | 04:10 PM
Matts ford's Avatar
yours is 2wd so theres no differential in the front. it looks like coolant to me but i guess go ahead and clean it up. if you use water be careful not to get any on the top end of the engine.
Old Nov 1, 2008 | 04:17 PM
Thanks Matt,
You can see the fluid in th first pic dripping from the 2 lines.
Are there any other fluids in the front besides:
engine oil
coolant
power steering fluid
brake fluid
What about automatic transmission fluid?
Old Nov 1, 2008 | 04:22 PM
Tans fluid is red. . .
Take a can of brake clean, spray the entire area that is soaked, make sure its really clean. Drive for a day, then look further for a leak. It reminds of AC oil, but that stuff is a tad more green. . .
Old Nov 1, 2008 | 04:42 PM
torkum's Avatar
Have you done a pressure test on the coolant system?
Old Nov 1, 2008 | 04:44 PM
Torkum,
Would A/C refrig feel like oil when you rub it between your fingers?
Old Nov 1, 2008 | 04:56 PM
beckerjs's Avatar
if you are only looking at the overflow container when checking the coolant you are not checking the whole system, check the radiator level if possible. Still looks like coolant to me. Smell it
Old Nov 1, 2008 | 05:10 PM
Smells like oil.
Old Nov 1, 2008 | 09:12 PM
wmcnally's Avatar
I don't know about your Expy but my truck has a tranny cooler. The lines from the tranny to the cooler look like those in your pics. It may be tranny fluid leaking from those lines.
Old Nov 1, 2008 | 09:18 PM
Matts ford's Avatar
tranny fluid is red. as yellow as that is i think it may actually be a/c oil with die.
