IAC Question
Old Oct 28, 2008 | 04:48 PM
G.LoomisMan's Avatar
IAC Question
i know the iac on my truck needs to be changed...anyone have pictures of what it is and where it is. 01 f150 5.4 screw. thanks
Old Oct 28, 2008 | 04:57 PM
Matts ford's Avatar
its right on the back of your throttle body. by the firewall
Old Oct 28, 2008 | 06:53 PM
how longs it take to change?
Old Oct 28, 2008 | 07:01 PM
Matts ford's Avatar
i cant remember but i think its roughly like only 10 minutes. its just 2 bolts and unplug it and its off. its guick and easy
Old Oct 28, 2008 | 08:36 PM
jethat's Avatar
you should clen the throttle body while replacing it. You dont have to but cleaning the throttle body WILL make your truck run better. There is detailed instructions for doing it at the top of this fourm.
Old Nov 8, 2008 | 09:11 AM
Devildog101's Avatar
What is an IAC and why do you think it needs to be replaced?
Old Nov 8, 2008 | 09:27 AM
jbrew's Avatar
Your not listening to well - Read the post by jethat and follow
Here's a shortcut -
https://www.f150online.com/forums/en...ttle-body.html
Old Nov 8, 2008 | 11:04 AM
warrantyvoider's Avatar
jbrew,
IAC stands for idle air control. on newer cars and trucks that are not electronic throttle control, the IAC is a stepper motor or linear solenoid and lets a controlled amount of air around the throttle plate. the IAC opens or closes a certain amount and allows a certain amount of air to flow through that passage and around the throttle plates. just as the name indicates, the IAC helps control idle.
Old Nov 8, 2008 | 11:23 AM
jbrew's Avatar
Originally Posted by warrantyvoider
jbrew,
Are you asking me if this is true ??? Or telling me??
In either case, why ?
Old Nov 8, 2008 | 11:27 AM
yetti96's Avatar
I think he was telling you because you were right above him and not the OP, lol.
Old Nov 8, 2008 | 11:32 AM
jbrew's Avatar
Yea , I didn't know where that came from haha - Couldn't figure out where I gave him the wrong impression ..
O-well
Old Nov 8, 2008 | 11:44 AM
jbrew's Avatar
Well, I guess I'll post something useful. The IAC -
