creepy sound
Old Oct 23, 2008 | 11:55 AM
kboozy's Avatar
creepy sound
Happy Halloween everyone!!!!!!!!!
On that note my truck think so to, it seem now that the cold is here my truck makes a nose like a creepy fog horn miles away LOL I thought it was my clutch fan but checked and it wasn't(fan Not moving)>> anyone have this problem?? it just last for the first few min on warm up
Old Oct 24, 2008 | 08:16 PM
kboozy's Avatar
nothin
Old Oct 24, 2008 | 08:25 PM
Matts ford's Avatar
does it do it when your driving? and do you have a cai? and could you describe it any better than that?
Old Oct 24, 2008 | 08:44 PM
kboozy's Avatar
No just in the first min after starting it.. I have SCT by Troyer and magnaflow, no CAI yet. I really thought it was the clutch on the fan but I held the fan and it was not moving and still herd the small horn sound coming from the front of the motor.. Sometimes its louder im lost I have 59000k on 5.4 4x4 original Belt. Maybe i need to put the gator belt on and see if that fixes it..
Old Oct 24, 2008 | 08:46 PM
jbrew's Avatar
Yea, it's either intake or PCV valve IMO. Anything other than a Motorcraft valve can be noisy. Motorcraft valves flow. Other aftermarket replacement valves have tight margins that restrict. Makes them noisy and you can use oil with them.
Damn , I can't hold my fan - even cold..My fingers didn't even slow it down a couple weeks ago. That still hurts.
Old Oct 25, 2008 | 04:36 AM
The fan should not be still on a cold start - your clutch may well be what's making the noise. It should roar for about 20 seconds and quiet down as the rpm's drop.
Old Oct 25, 2008 | 07:25 AM
vince2008's Avatar
Bingo glc
Old Oct 25, 2008 | 10:24 AM
kboozy's Avatar
LOL, ya my fan just barely moves and i can stop it really easy? But driving when its cold you can hear the fan amp up loud then tapers down as she warms up...I think my valves are motorcraft I have never messed with them.
Is the PCV valve something I could change and maybe fix? And on that should I go ahead and just replace anyway
Old Oct 25, 2008 | 10:34 AM
Matts ford's Avatar
the pcv valve should be right on your passenger side valve cover. what are you going to do about your fan clutch? as glc said it should be moving.
Old Oct 25, 2008 | 01:42 PM
You should never be able to stop and hold the fan - regardless of temperature.
Old Oct 28, 2008 | 04:41 PM
kboozy's Avatar
Really did not know this... Well any ideas? Do i need to replace or are their ways to tell if it can be fixed..
im going to replace the pcv for sure cheep fix if it works..
Old Oct 28, 2008 | 05:10 PM
Remove the drive belt and start it. If there's no noise, it's most likely the fan clutch.
Old Oct 28, 2008 | 06:38 PM
wreedKR's Avatar
replace the fan cluth, did this the other day to a buddies truck.
Old Oct 29, 2008 | 01:51 PM
kboozy's Avatar
How much to replace fan clutch your self? mine i can stop when its cold..
Old Oct 29, 2008 | 02:08 PM
A Motorcraft fan clutch is 100 bucks at rockauto.com, aftermarket clutches are about 75 bucks at Autozone. Before you do it, pull the belt like I suggested and verify that it shuts up. You only need to run it for about a minute which will be safe.
