missfire after replaciing air filter
Old Oct 20, 2008 | 03:49 PM
beechkid's Avatar
25 Year Member
Originally Posted by Matts ford
the oil from the K&N may have contaminated the maf. or maybe your engine can now breathe but isnt getting all the fuel it needs to run right. when was the fuel filter last changed?
Guaranteed answer!!! You can try denatured alcohol to clean the MAF but it's about a 1/3 chance you will be successfull- might just have to change to MAF.
Old Oct 20, 2008 | 05:46 PM
jbrew's Avatar
The Pro's use Windex .. - Or is that the Greeks?
Old Oct 21, 2008 | 01:17 PM
Clean the maf again, CRC electronic cleaner is fine. Let it dry for 15 minutes before you start it. If that doesn't fix it, its plugs and (maybe) cops time. As I said, 90k is right around plug change time anyway. My plugs, wires, and coil pack only made it to 84k.
Old Oct 21, 2008 | 01:37 PM
ah1200's Avatar
Sounds like a bad coil. Power brake in gear with out spinning tires if it misses you have a bad coil good luck finding the right one unless you have scanner. Also I would replace spark plugs before one blows out of the head very big problem in that year.
Old Oct 22, 2008 | 12:39 AM
Bluegrass's Avatar
Another variation.
If it fits this discription, you have a bad coil.
'Misses at light throttle in OD but not under heavy throttle load or a down shift.
Reason is the fuel mix in very lean under those operating conditions and a coil with "shorted turns" has low output on one cylinder but is not totaly dead.
This kind of fault will not set a code or a CEL.
Why after changing or servicing the air filter is just a coinsidence.
You have to address the issue and not spend time trying to link it to some other action.
Sometimes there is more than one problem present and have to be recognized and delt with seperately.
Good luck.
Old Oct 22, 2008 | 07:03 AM
tjk_in_cny's Avatar
I had a similar problem 6-7 months ago. (I use paper filters.)
I took my air cleaner housing apart to get to the MAF sensor to clean it. I thought I had it cleaned but was still having a problem. After a couple of days of the same problem, I bought a new can of CRC Electronic's cleaner. I stripped down the filter housing so I could get a better view of the MAF and found that there was still "gunk" built up on the super thin wires. I took my new can of CRC cleaner and sprayed the crap out the sensor. When I was done, it looked like a new sensor from the box. The new can had 100% more pressure than the can I had sitting around.
Problem went away.
This may or may not help you fix your problem but it will assure you that your MAF is clean and you can eliminate this as a possible cause.
Good Luck
TJKinCNY
Old Nov 17, 2008 | 01:28 PM
Bigtruck777's Avatar
missfire
well it really started missfiring worse than ever and it finally threw me a code. The code was #1 cylinder misfiring. Which one is the #1 on this truck, 2001 5.4 ? Someone said #1 is on driver side in front, is this correct?
Old Nov 17, 2008 | 02:07 PM
jbrew's Avatar
No that's not right.
Old Nov 17, 2008 | 02:34 PM
missfire
well then it must be #1 is in front on passenger side!!
Old Nov 17, 2008 | 02:51 PM
JMC's Avatar
JMC
25 Year Member
Yes. Just so you know #2-3-4 are on the same side as #1
Cylinder #5 is on t he driver side in front followed by #6-7 and 8.
Regards
Jean Marc Chartier
Old Nov 17, 2008 | 09:09 PM
joemac53's Avatar
Change air filter
Make sure you check the lower right plug wire under the clamp for the air filter. While you wrestle with the housing for the air filter you might pry off the plug wire from the ignition coil.
Been there, done that.
Old Nov 18, 2008 | 07:41 PM
changed #1 cop, truck is fine now, Thanks to All
Old Nov 18, 2008 | 07:50 PM
Matts ford's Avatar
no offense but how the he!! do you pull off the #1 cop plug with the air filter housing? there both on different sides of the truck
cool deal
Old Nov 22, 2008 | 07:37 PM
Smile
No **** Sherlock, I didn't pull off the #1 when I changed the air filter, I guess it was just coincidence that the coil went right after I changed the filter!!
Old Nov 22, 2008 | 07:44 PM
jbrew's Avatar
Yea, that takes talent
