IAC Valve
Old Oct 15, 2008 | 05:55 PM
dkelley2000's Avatar
IAC Valve
Can anyone tell me the exact whereabouts of the IAC Vavle on my 2006 F150. It's a 4.6L V8 XLT.
Also, does anyone other than Ford sell the part yet? Can it be cleaned, etc. to clear the engine code?
Old Oct 15, 2008 | 05:57 PM
Matts ford's Avatar
what codes?
Old Oct 15, 2008 | 05:59 PM
Matts ford's Avatar
once again i made a mistake. there is no iac on the 06 f150 it is all done through the electronic throttle body.
Old Oct 15, 2008 | 07:00 PM
IAC Codes report
I am getting
PO506
Idle Control System Low RPM
Ford Dealership told me that was an IAC Valve.
Wanted to almost $400 to replace the part, etc.
Old Oct 15, 2008 | 07:09 PM
Matts ford's Avatar
i think they wanted to replace the throttle body. i'd search more info on that code for 2004-2008 f150's.
Old Oct 15, 2008 | 07:19 PM
Matts ford's Avatar
https://www.f150online.com/forums/en...0506-help.html
https://www.f150online.com/forums/en...-stalling.html
heres a couple of threads to look at. your truck does have an iac but i believe it comes a whole unit and its not the normal style. at least i think ford replaces it as one unit.
Old Oct 16, 2008 | 07:15 PM
Still Confused
I've heard now that there is an IAC and that there is NOT an IAC on a 2006 XLT 4.6L V8. The P0506 that I keep getting is for Idle Lower than expected (but my vehicle is not running rough nor stalling, etc.) I decided to go ahead and clean the throttle Body with cleaner and clear the engine light. That was 2 days ago and the engine light has not come back (YET?).... but when/if it does......
can anyone tell me WHERE the IAC (assuming there really is one) on the engine that I have. What does it look like (electrical connector with 2 bolts? or what?)
Anyway, thanks to all that can give me guidance.
Next challenge is to find a place to actually buy one. Seems only Ford/Motorcraft? sells them.
Thanks again.
Old Oct 16, 2008 | 07:58 PM
jethat's Avatar
Thanks again.
No IAC 04+ As was already posted the fly by wire throttle body replaced it.
Old Oct 20, 2008 | 11:16 AM
Low RPMs
as posted, I was getting a P0506 code.....low idle speed.
i cleared the code and cleaned my throttle body with cleaner. so far the code has not come back after about 60 miles.
although truck is running okay, not idling rough in my opinion, it shows just slightly below 750 rpms on the tach.
should i get a full tuneup or just ask to have the electronic idle adjusted????
Old Sep 19, 2009 | 11:52 AM
CBAILEY's Avatar
I to have recieved the same code. I am running a lighting tuner on an '05 5.4. I cleared it thursday, and it returned friday. I recently wrote a custom level 2 program and added 1 deg of timing but forgot to increse the idle. The extra timing is amazing, it woke my truck up. But the idle lobes around 500-600 rpm in gear. today I am going to increase the idle and I will let you all know how it goes
Old Sep 19, 2009 | 04:55 PM
ONELOWF's Avatar
Interesting. What is a lighting tuner?
