misfire please help
Old Sep 26, 2008 | 12:02 PM
gpmatt08's Avatar
Unhappy misfire please help
So about three weeks ago on the way back from college to visit my parents my check engine light came on and i noticed a bad misfire so i finished out the drive (only about ten miles). When i got home i had an auto part store read the codes and i figured out i needed to replace two coils, after that it ran perfect better than ever actually. Then a few days ago the misfire was back :/ i figured i may of had some water get in to cylinder 4 and 2 so i replaced the plugs it seemed to run good for about half a mile then the misfire was back, so then i thought maybe i was getting bad fuel so i replaced the fuel filter. It ran good for about two miles then the misfire again. IDK where to go next, please help oh and its a 99 5.4L f150 lol
Old Sep 26, 2008 | 12:10 PM
Camarothatcould's Avatar
This is unclear. . .
"i had an auto part store read the codes and i figured out i needed to replace two coils, after that it ran perfect better than ever actually"
So0o0o, did you replace the coils or not???
Old Sep 26, 2008 | 12:33 PM
gpmatt08's Avatar
ya sorry, i replaced the coils
Old Sep 26, 2008 | 12:58 PM
shifty_85's Avatar
replace all the plugs...are you throwing any more codes with this mis-fire? make sure to use only Motorcraft plugs..triton motor will mis-fire with just about anyother plug in there.
Old Sep 26, 2008 | 01:37 PM
have the codes checked again? Maybe other COP's are going bad...
Old Sep 26, 2008 | 01:43 PM
shifty_85's Avatar
reaplce all COP's and plugs..why just 1 or 2?
Old Sep 26, 2008 | 02:18 PM
cj2112's Avatar
Did you use di-electric grease on the boots and contacts?
Old Sep 26, 2008 | 05:26 PM
Matts ford's Avatar
http://cgi.ebay.com/ebaymotors/Parts...=p4506.c0.m245 heres a set of 8 global cop's on ebay so you dont go out and spend alot of money on napa or motorcraft. and definately use motorcraft plugs. and dont forget the dielectric grease.
Old Sep 26, 2008 | 06:11 PM
Since di-electric grease is not conductable, I thought it wasnt sopposed to be spread on the direct contacts? I thought it was just for water proofing and dry socket avoidence
Old Sep 29, 2008 | 08:51 PM
cj2112's Avatar
Yep, that was the point I was getting at. If you spread it on the contacts, then it would certainly be missing.
