The weirdest thing....
Old Sep 9, 2008 | 10:14 AM
chumFX4's Avatar
My truck had the dreaded engine "tick" since I bought it (used, 24K) it now has 70K on the odo. The tick was pretty loud and annoying, but I learned to live with it. About 2 days ago, it stopped! Now it runs nice and quiet. I have done nothing as far as service since my last oil change a month ago. Go figure........
Old Sep 9, 2008 | 10:27 AM
exitwound's Avatar
I wish mine would do that.
Old Sep 9, 2008 | 11:15 AM
UCF-150's Avatar
mine ticks bad right at start up. After that, it doesn't completely go away, but it's hardly noticeable. I've always attributed it to the oil draining out of the heads / lifters and it ticks until the oil pressure builds up pushes oil back up there.
Old Sep 9, 2008 | 11:23 AM
You are not using a Fram or a cheap lube joint filter are you? The anti drainback?
Old Sep 9, 2008 | 11:47 AM
IR0NS1N's Avatar
Get a WIX oil filter with anti drainback to prevent lifter tick. Only ticking my motor does is the stock injectors. I dunno if aftermarket will do it too but I dont mind either way.
Old Sep 9, 2008 | 11:48 AM
Yep, Wix, Purolater, Motorcraft, to name a few. All good.
Old Sep 9, 2008 | 12:01 PM
UCF-150's Avatar
I use the mobil1 blue filter along with mobil1 5w20
I use the same on my girls '04 f150 2wd screw and hers doesn't tick.
Old Sep 9, 2008 | 12:09 PM
That should be a good one, doubt that is the noise maker.
Old Sep 9, 2008 | 12:25 PM
UCF-150's Avatar
maybe it's injector tick like IRONS1 said he has?
Old Sep 9, 2008 | 12:56 PM
Injector tick or cam phasers.
Old Sep 9, 2008 | 01:44 PM
MitchF150's Avatar
Or even a busted exhaust manifold bolt or two.....
