Air Box Mods?
Old Sep 3, 2008 | 11:27 AM
countrywill's Avatar
Air Box Mods?
Has anybody tried the "Air Box Modification" thats in the tech articales?
Old Sep 3, 2008 | 12:25 PM
Dankle666's Avatar
Yeah. I have it done on my truck at the moment. I don't know if I actually gained or lost anything. You can definitely hear the difference at some RPM's.
Old Sep 3, 2008 | 03:43 PM
02SCSB5.4L4x4's Avatar
I actually did something similar to mine (without having seen the tech article) and have been impressed with it. What I did was pretty close to the article except I purchased a spare airbox piece (half that houses the filter) at the local junkyard for $5, and cut off the end that goes into the fender, and the top and front sections of the filter housing (except the ring that holds the filter in). So it's basically the same as the article except my filter is a little more protected from any mud or water I might get into. I didn't notice a real huge difference but it seems like it's breathing a lot better.
Old Sep 3, 2008 | 08:59 PM
Fifty150's Avatar
I installed the Airaid Cold Air Intake.
Old Sep 4, 2008 | 01:50 AM
Thanks for the responses. I'm thinking about doing it here in a couple of weeks when I get back from CA.
Old Sep 4, 2008 | 09:53 AM
Veteran: Army
check out the "gotts intake" it's reversable if you don't like it, I actually prefered it to my K&N
Old Sep 4, 2008 | 04:16 PM
jbrew's Avatar
Yep , the gotts intake is all I run now - Run that with the stock set up. - Plenty of COLD air on demand. #1 intake mod for the close to stock set ups.
Old Sep 4, 2008 | 08:22 PM
tucker27's Avatar
hey i am new to this website and what i did on mine was made a ram air kit that goes with my ram air hood, when i get some pics i will post them up for u all.
Old Sep 7, 2008 | 12:26 AM
OhioLariat's Avatar
I don't like the idea of the motor breathing hot underhood air, so I removed the snout from my stock aircleaner, and used a piece of ABS pipe (3" IIRC) reamed out a bit to fit over the end. Applied some foam tape to the side of the engine compartment around the hole that leads to the fenderwell, and voila! Better breathing and still drawing cool air. (Cost me nothing but time, as well, since I had a scrap of pipe.)
No noticeable difference, but worth the cost.
Andy
Old Sep 7, 2008 | 10:14 AM
tucker27's Avatar
here what i did to mine, its on youtube though heres the link (http://www.youtube.com/watch?v=QixQM4UI3E8)
Old Sep 7, 2008 | 03:06 PM
Veteran: Army
Andy
that's essentually the "gotts intake"
