01 f-150 5.4 powerdyne
Old Aug 15, 2008 | 04:26 PM
bassmaster's Avatar
i have a 2001 f-150 5.4 with a powerdyne charger,airraid throttle body spacer, k&n filter and flowmaster exhaust, can anyone tell me how to make it faster please....
Old Aug 15, 2008 | 04:56 PM
Veteran: Army
ditch the throttle body spacer...
look into swapping the fmu, for 39# or 42# injectors, a 90mm MAF, a 255lph in tank fuel pump a good dyno tune, if you are not innercooled add an innercooler right away then crank up the boost to 10-12psi after the innercooler.
long tube headers and efans will help too
check out the supercharger / turbo charger room and look at the sticky's for mods and dyno sheets
Old Aug 16, 2008 | 05:12 AM
Veteran: Army
I forgot to ask what powerdyne kit are you running? and is it innercoolercooled or not?
Old Aug 16, 2008 | 06:37 PM
ONELOWF's Avatar
Also, what size is the upper pulley?
Old Aug 30, 2008 | 12:43 AM
bassmaster's Avatar
my kit is a bd 11-a my upper pulley is 2.93 which is supposed to put out about 9 pounds and it is not intercooled.
Old Aug 30, 2008 | 04:55 AM
phil6608's Avatar
Get rid of the throttle body spacer,,it's not helping and may even be hurting your performance!
An inter-cooler or a water/methanol injection kit would help.
Long tube headers and high flow cats will get ya about 30 HP or more.
If you want to spend some money,,you could get ported heads and performance cams.
Phil
