Engine Tapping
Old Aug 14, 2008 | 12:38 PM
spicedog9's Avatar
Engine Tapping
I have a 2004 Ford F-150 Supercrew with a 5.4 engine and I recently changed my engine oil with 7 quarts of 5w20 oil and I noticed some minor tapping coming from the engine. I have never experienced this with any of my other Ford Trucks and would like some advice on maybe an engine additive or should I take this a little more serious.
Old Aug 14, 2008 | 04:14 PM
f150fella08's Avatar
wow i think the new trucks only take 6 or 6.0, that may be why your engines tapping, if not that it might be the oil your using, i know many people have switched from regular oil to mobil 1 in fords and it stopped knocking and all that other stuff
Old Aug 14, 2008 | 04:43 PM
chiefFX4's Avatar
the new trucks take 7 quarts of oil. seriously getting tired of correcting your mistakes fella.
describe the tapping. could be cam phasers.
Old Aug 14, 2008 | 05:28 PM
Maxout05's Avatar
It probably the same "ford knock" every 5.4 does and you didn't notice before. But to be sure bring it to a mechanic and let them listen to it.
Old Aug 14, 2008 | 05:40 PM
the new ones take 7, anything before that takes 6 thank you i change oil every day
Old Aug 14, 2008 | 08:03 PM
bxstang2000's Avatar
Yeah it seems all these trucks with the 5.4L have a slight engine tick. I brought mine to the dealer and it was "normal". And yeah these are 7 Quarts...
Old Aug 14, 2008 | 08:18 PM
Matts ford's Avatar
it may quiet down if you use a little thicker oil or a lucas oil additive. the 5w20 is like water. i run synthetic 15w50 in my little 5.0 in the summer and 10w30 in the winter.
Old Sep 15, 2008 | 02:12 PM
diggman08's Avatar
put some Lucas Oil Stabilizer in ( 1/2 quart) when changing oil.. and make sure you get a good oil filter with a good drain check valve.. i had the same problem and cured it with these things.. o yeah i a used Penzoil Platinum PUre Syntheic good ****
Old Sep 15, 2008 | 03:05 PM
If you are using Motorcraft 5W20 and a Motorcraft filter, it's not an oil issue.
Old Sep 15, 2008 | 03:08 PM
Correct. You may be hearing the injectors, they do a light ticking at idle.
Old Sep 16, 2008 | 03:02 AM
itimebomb89's Avatar
Amsoil
Amsoil boys...
Gimme an email
Gregoryb89@verizon.net
