what changes were made to 2008 4.6?
Old Aug 14, 2008 | 08:51 AM
Pilot's Avatar
Just bought a 2008 screw yesterday with a 4.6. This is my 3rd Ford truck. I have owned a 2000 super cab, 2001 screw and now this 2008. I see the HP on the 4.6 in 2007 was 231 and in 2008 it is up to 248 HP. What changes were made?
Old Aug 14, 2008 | 11:40 AM
06yz250f's Avatar
i think 07 they bumped it up to 248. not 100% sure but i remember reading they upped the power on the 07's from 06's.
just to let you know if you plan on CAI. 04-06 systems will not fit on 07-08. throttle bottle is twisted instead of straight so it will not line up.
Old Aug 14, 2008 | 06:10 PM
Faster150's Avatar
the lower runners on the intake manifold and plenums were port matched. the intakes runners are cleaned up quit a bit. thats the one physical difference i noticed. and im sure they changed the tune added degree or so of timing.
Old Aug 14, 2008 | 06:43 PM
4.6 Punisher's Avatar
A cleaned up plenum and a slight tune adjustment gave that much power?!
Old Aug 14, 2008 | 08:45 PM
Faster150's Avatar
yep. i wish i had before pictures of the one i ported for pat. i just got after pics.
Old Aug 14, 2008 | 08:47 PM
Faster150's Avatar
lower plenum
all ireally did was clean it up a little bit and knife edge the inlets not to sure how much it will help but i guess well find out
might make an interesting intake noise.
Old Aug 14, 2008 | 09:03 PM
Interesting..... but brilliant!
Old Aug 14, 2008 | 09:10 PM
scott1981's Avatar
Faster150
How much time does a project like that take? Is it pretty easy to do?
Neal's Avatar
Cool
HI!... Knife edging where you did will do nothing. If anything you just hurt flow due to now you will have a fair amount of turbulence where the lower and upper plenum meet in those areas. You should of removed the center divider in the primary intake port though.
Like this :
These are perfectly gasket match. Can't go larger unless you cut into the gasket.
Here's the upper :
Old Aug 14, 2008 | 09:16 PM
Neal's Avatar
Cool
HI!... Here's the intake ports :
Old Aug 14, 2008 | 11:12 PM
Faster150's Avatar
Like this :
Here's the upper :
yeh i removed the divider the next day i had just spent 4 hours on it. took a break. pats got it now so hell have new pics of it.
Old Aug 14, 2008 | 11:14 PM
Faster150's Avatar
Originally Posted by scott1981
Faster150
took me about 5 hours total to do it
burned up the bearings and ceramic brushes on my Makita die grinder though lol.
big cost it the tools and the carbide aluminum burs that are single cut. their about 30 bucks a piece for good ones. the cheap ones will chip and screw up ur cut. but this is the 4th intake ive done. but the one going on my new motor im having CNC ported to match my heads. to expensive for me to piddle with
