Driver side Manifold
Old Aug 12, 2008 | 09:51 PM
Camarothatcould's Avatar
All the studs are intact and so are the two studs that connect the manifold to the downpipe. I still have a huge exhaust tick. Do you think its worth it to remove the manifold, hoping no studs break, and replace the gaskets?
Drilling and tapping the passenger side was hard enough, let alone driver side I have to deal with brake lines and steering components.
Old Aug 12, 2008 | 09:53 PM
minimonster17's Avatar
yes, its worth it. its not that bad. you don't have to disconnect anything else, there is just more in the way. the only thing that might be a hassle is the engine oil dipstick tube. if possible, work around it, and do not disconnect it. it is a bitch to pull out and may snap.
Old Aug 12, 2008 | 09:55 PM
Originally Posted by minimonster17
yes, its worth it. its not that bad. you don't have to disconnect anything else, there is just more in the way. the only thing that might be a hassle is the transmission fluid dipstick tube. if possible, work around it, and do not disconnect it. it is a bitch to pull out and may snap.
You mean oil dipstick tube? Trans tube is on the passenger side
Old Aug 12, 2008 | 09:58 PM
yes, you replied before i fixed my post. if it snaps, it is a bitch to get the broken portion out. when i removed my manifold, i fought and cursed the broken piece for half an hour before i got it out.
on an F-150 you don't have to disconnect brake lines/steering. i would assume the same on your 4WD Expy.
Old Aug 12, 2008 | 10:00 PM
sorry, haha. This time I will use my 3/8 impact on the nuts, hoping they all stay intact and I wont have to replace any. Anybody know the torque spec on the exhuast studs? I'll also have help from Mr. Pb Blaster
Old Aug 12, 2008 | 10:02 PM
you know the correct pattern for tightening, right. like this: 1x3x5x7x
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxx2x4x6xxx8
lemme look up the torque spec. gimme a min.
Old Aug 12, 2008 | 10:04 PM
you know the correct pattern for tightening, right. like this: 1x3x5x7x8
I actually do not know the pattern. I just cris-cross to pull evenly, is there a diagram, cause I do not know what studs are numbered what.
Old Aug 12, 2008 | 10:08 PM
number 1 in my diagram would be the first one on the top left if you are looking at the manifold. number 2 would be diagonally down, then number 3 diagonally up and so forth. the spec on the studs is 89-115 in/lbs.
the spec on the nuts is 17-20 ft/lbs.
do you need me to post an actual illustration?
Old Aug 12, 2008 | 10:12 PM
No thanks, I think I got it...
thanks for the spec!
Old Aug 12, 2008 | 10:14 PM
if you torqued them in a different way on the other side, you may want to retorque them to the sequence i posted in order to prevent leaks.
Old Aug 12, 2008 | 10:15 PM
I used bolts on the other side, but I planned to re-torque them to make sure there good n tight. thanks
Old Aug 12, 2008 | 10:19 PM
i personally prefer bolts as well. if the spec seems odd or awkward w/o the studs, use your better judgement. i did not torque mine to that spec, and have not had any leaks in over a year. remember you are tightening into an aluminum head...
Old Aug 12, 2008 | 10:21 PM
I know, I spent several hours drilling and tapping into pass side. very nerve racking. lol
