Help!
Old Aug 11, 2008 | 08:03 PM
CD1's Avatar
CD1
Help!
When I started my truck this morning it started up then sputtered and died. Hmmmmm....
I start it again...it sputters and dies. If I hold the gas a bit while I'm starting it I can get it to run but if I let off the gas at all it sputters and dies.
I changed the fuel filter tonight on the off chance that was the problem...nada.
Any ideas? The only other problem lately has been on hot days it will occasionally do the same thing, then start on the second or third try. It doesn't happen often...maybe once a week.
Old Aug 11, 2008 | 08:09 PM
Matts ford's Avatar
we need vehicle info. or else we would just be playing a guessing game.
Old Aug 11, 2008 | 08:44 PM
buckdropper's Avatar
From: south western NYS Latitude: 42.34 N, Longitude: 78.46 W
Yes it is your IAC just behind the linkage for the gas cable. Tap it a bunch of times to see if you can get it working again. (or replace it.)
Old Aug 11, 2008 | 08:56 PM
CD1's Avatar
CD1
I got the truck to idle at about 500 RPM earlier, then I took out a wrench and tapped on the IAC...bingo...idle popped right up to 800 RPM like magic.
Then I came in here and saw your post...you know your stuff.
Thanks!
Old Aug 12, 2008 | 10:37 PM
Thanks!
I am glad you figured it out. I would put some wd 40 all around it the stuff is amazing...
