04 5.4 into my 2001 ford f150
you'll need more than just the engine, you'll probably need a new harness, and perhaps a new pcm as well. btw, the guy who swapped in a v10 into his F-150 is a Ford Tech, and had to use a whole load of superduty parts in order to get his truck working properly. in the end, you may find it to be cheaper to drop another 2v 5.4, and bolt ons to upgrade your hp.
Not likely.
No motor swap is simple.
Motor swaps always take longer than planned, there are always problems and hang-ups of some kind that come up and things never go 100% according to plan.
Never take on a motor swap thinking it will be simple.
The '04 swap has been done and this is a detailed thread about it:
https://www.f150online.com/forums/en...2004-4-6l.html
